Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
A/C compressor not engaging ?
Old 05-12-2014, 07:57 PM
d-ramey's Avatar
Default A/C compressor not engaging ?
it was 86 today in ohio i kicked the ac on and wow hot air , i had it on about 1 week ago it was pretty cold in the city until i got on the freeway which made no since at all so i figured it was low so i bought a can of freon put it nothing happen the gauge said i was in the range it needed to be the condenser fan was even on i checked the fues relays and everything i even spun the clutch on the compressor to make sure it wasnt locked up !!!!
any suggestions or known issues with the 2006 tsx 6speed ac units? i have a friend who can drain it alll and put it back in like it was new again should i start there? thanks
Old 05-13-2014, 04:35 PM
WanaBeFaster's Avatar
Default Re: A/C compressor not engaging ?
Pull the compressor relay and see if it rattles when you shake it, check for power at the compressor with a/c on and car running. look at the clutch and it see it it's reddish brown/burnt looking. more common problem is the clutch and stator going out, the relay rattling is a dead give away. if freon is at proper pressure, clutch is usually bad.
Old 05-14-2014, 05:43 PM
d-ramey's Avatar
ive switched the relays around if that helps? so take it out see if i hear loose parts shaking around
Old 05-19-2014, 04:51 AM
oldschoolmaster's Avatar
u need a clutch,stater and relay I did these every week when I was a head tech of acura
Old 05-23-2014, 05:47 PM
Never throw parts at a car. Find out what's wrong with it and fix it right. Clutch, stator and relay are common, but not definite.
EcRzFinesT
Honda Civic (2001 - 2005)
19
08-11-2015 08:20 AM
kvastek
16
08-02-2013 07:24 PM
PL_RACER
Honda Civic (2006 - 2015)
07-24-2012 07:20 PM
imjustagirl
08-19-2007 08:54 PM
adan CRX
11-26-2003 08:41 AM
Quick Reply: A/C compressor not engaging ?
