Brake Pedal Light once on won't go off
Old 05-09-2014, 07:25 PM
Manmeetsingh's Avatar
Default Brake Pedal Light once on won't go off
Hi
Bought 1996 Honda Accord a few months back. On starting the Car, when I push the Brake pedal to take off the Hand Brake, the Brake Light comes on but won't go off even on releasing the brake pedal on Dashboard. Even the Hand Brake light stays on. Brake works perfectly, just the dashboard lights stay on, the rear brake lights go on and off perfectly. I've checked the brake pedal under the steering and the brake plug is fine. Can't figure out why this is happening? Any help will be appreciated...
Old 05-09-2014, 07:36 PM
Torres123's Avatar
Default Re: Brake Pedal Light once on won't go off
do you have the proper amount of brake fluid? check your brake fluid level.
Old 05-09-2014, 07:48 PM
i checked... There is sufficient brake fluid.
Old 05-10-2014, 02:23 AM
holmesnmanny's Avatar
either a brake light is out (perhaps the high mount bulb) or the brake circuit check sensor is bad
Old 05-10-2014, 03:23 AM
Thanks.... will check accordingly.
Old 05-20-2014, 08:06 PM
You were spot on... Brake light was out. Fixed... Thanks
sonson6
04-08-2007 05:58 PM
white99accordEX
12-22-2005 04:08 AM
94BlackRS
11-28-2002 02:43 PM
SlowazzGSR
06-07-2002 10:30 PM
Quick Reply: Brake Pedal Light once on won't go off
