1994 honda accord EX transmission compatibility help..
so I need to know are what other trannys are compatible..
mine is automatic.. I heard the 1997 autotrans would work but i need to use the 97s torque converter?
well any help would be great..
MM Gruppe B
Re: 1994 honda accord EX transmission compatibility help..
Any trans from a car with an F22 engine. F23 engines came with the next generation of transmissions.
'90-'93 Accord, '94-'97 Accord, 92-96 Prelude, '97 CL, and '94-'97 Odyssey
OBDI vs OBDII does not matter.
the tranny came off a 92 prelude.. and on the tranny closest to the fire wall there are 2 rubber tubes that my 94 tranny did not have.. what do i do with them?
does the old speed sensor bolts up without mods? it has a keeper type thing inside that spins it. i don't know if the gear is different
just read its safe to loop that. https://honda-tech.com/forums/showthread.php?t=2884842
https://honda-tech.com/forums/showthread.php?t=1021907
thanks a ton
MM Gruppe B
Just pull your old VSS from your Accord trans and put it on the Prelude trans.
H4A is an H4A. Just different gearing.
mad mike he said they were different sizes. don't believe me, he sent me a pm and that is what he wrote. i recommend swapping them and thats when i got pm'd that
