Guy gave me the wrong cluster or something?
I Went to the wreckers and asked for a 96-00 Honda civic cluster the guy gave me one (has a tachometer, mine didn't) I tried to install it but it doesn't have a slot for the orange pin, if i need to plug that in..
pics here
Help is greatly appreciated
pics here
Re: Guy gave me the wrong cluster or something?
Just took another look, Is the plug for the orange clip under that thing next to the yellow clip?/if so howcome it hadn't been used
Stancetard Hate Monger
the yellow plug is for srs, you should have a yellow connector for it. plug the other two wire ends into their respective places, make sure theyre connected securely. fyi- you can put your odometer/speedometer into that cluster to retain accurate mileage
I plugged everything in but no rev and stuff.. could the cluster be broken?/ what is that orange cable for
Could the thing down the bottem left on the second pic be a possible fault?
Yes they look bad (the power + and - trace might be broken). If the temperature gauge don't work, you can jumper the temp + to the tach. + and the temp - to the tach -.
Roryz
14
04-23-2014 02:16 AM
integraXTC
10
06-12-2011 02:43 PM
sohcvtec91hatch
01-24-2007 02:12 PM
sol2hatch
02-09-2006 08:43 PM
