Turbo Prelude Question
Old 04-21-2014, 04:01 PM
Profounded's Avatar
Default Turbo Prelude Question
Hey guys i was wanting to know if anyone had any part suggestions for building a turbo H22A1 engine? Im trying to build it right but not go all out because of cost i would like to stay in the 6k-8k range cheaper if possible. This car will still be my daily driver. I would just like to see some suggestions based on experience or knowledge, thanks in advance guys.
Old 04-21-2014, 04:11 PM
95accordCE6's Avatar
Default Re: Turbo Prelude Question
What is the power goal? You have to build around that
Old 04-21-2014, 04:52 PM
Profounded's Avatar
Honestly Im not sure what would be something realistic? Im don't know a whole lot on the subject witch is why im asking you guys from the research ive gathered all ive really found out for certain is i need sleeves and new pistons for sure.
Old 04-21-2014, 05:13 PM
H22s are capable of a fair amount, and although I'll admit by no means am I an h series expert I have heard of 400hp plus, but it all depends on the cars use. A daily driver I would recommend setting a lower power goal so it's more streetable. I would add to that list stronger rods, arp head studs and main studs, cometic head gasket, upgraded tbelt. How much power you can make is based almost entirely on supporting mods and tuning. A good mess should also be added to your list
Old 04-21-2014, 05:18 PM
Profounded's Avatar
I will keep that in mind and if im not going to be running my car very hard just want to have a turbo and add more power plus a little more fuel economy would something like this be practical without many other upgrades with it? And Sorry if you think these are stupid questions I just want to go about this the right way.
Old 04-21-2014, 05:28 PM
It'd be more stupid to not ask and just throw something together and trash the block. There's a lot of baggage that comes with turbocharging...like the engine internals, engine management, drivetrain. I would put off buying things for a while and get to know every detail about your engine, like its strong points (closed deck design) and weak points (frm sleeves) and figure out just how much more power you want
Old 04-22-2014, 07:32 AM
moderator emeritus
98vtec's Avatar
how many miles are on the engine?
have you performed a compression test to see if the engine is healthy enough to turbo?
have you performed a cylinder leak down test to ultimately determine how healthy the engine is?
for a daily driver, i would keep it under 300whp (based on the dyno i use). I am running, and have been for a good while, 380whp on the stock engine. However, my engine is healthy and I have nice/efficient parts on the engine and it is tuned very well.
start with the basics first. You need to understand how everything works too so you know how to maintain it properly.
Old 04-22-2014, 11:28 AM
Profounded's Avatar
Thanks for the advice do etheir of you have any good refrences or somewhere i can start reading ect because im not really for sure where to start
Old 04-22-2014, 11:54 AM
Sparksman's Avatar
Google is your friend.
Just start reading a thread of someones car similar to the build you have in mind. Anytime you see something you dont know what it is stop, open a new window and read into that. Then when you know, go back and continue reading the original thread. Things will make more sense when you see how they work together as a system.
Its a snowball effect, at some point you wil have 10 windows going and reading until your eyes hurt lol. Eventually you will have a good grasp of whats needed.
Old 04-22-2014, 01:10 PM
Agreed
eddy1
14
09-24-2007 07:34 PM
b20turboic
11-09-2006 08:57 PM
Idiotboy
07-07-2006 10:58 AM
RACEPAK
10-19-2005 08:56 AM
havoc productions
08-25-2003 11:17 AM
Quick Reply: Turbo Prelude Question
