CRX Roll cage
Old 04-20-2014, 08:59 AM
THECRX's Avatar
Default CRX Roll cage
Upgrading to a 10pt cage and wondering where the crx/ef guys put the bars through the dash with out annihilating the stock dash. Any help would be greatly appreciated
Old 04-20-2014, 09:11 PM
raene's Avatar
Default Re: CRX Roll cage
I cut triangles out of the corners of the stock dash... was able to retain most of the heater ducting with a little creative duct tape usage
Old 04-21-2014, 06:41 PM
imptricer's Avatar
if the windshield is out take a torch and heat up a 3-4 foot piece of cage material and melt it through the dash you will be happy with the turn out cant get a tighter fit. if it were me i would take out the windshield if its not you will be more happy with the fit this way
Old 04-22-2014, 02:33 PM
raene's Avatar
Can't argue with the fit comment but good luck taking your dash out after that
Old 04-27-2014, 08:22 AM
90 JDM EF8's Avatar
No matter what your gonna have to cut your dash if you want it to go back on. Heres a couple pics of my passenger side on my crx. Dash still bolts up in all factory locations. My cage builder did it all with windshield still in and it didn't turn out too bad.
https://honda-tech.com/attachment.ph...1&d=1398615584
Old 05-10-2014, 08:01 PM
andersen's Avatar
I have mine so I can still take my dash out. and my VIN # can still be put back.
Old 05-21-2014, 10:53 AM
THECRX's Avatar
Went ahead and went through the vents. About to make a magic with the inserts and put them back in.
Old 05-21-2014, 10:58 AM
THECRX's Avatar
a few more
Old 05-21-2014, 11:00 AM
THECRX's Avatar
2 more from theback
Old 05-27-2014, 07:33 PM
90 JDM EF8's Avatar
Looks good!
Old 05-31-2014, 07:56 AM
stenseltizm's Avatar
How did you get the dash back in?
Did you run a dash bar?
Mine is right about the same place and I'm trying to decide how to move ahead.
Old 06-11-2014, 06:22 AM
THECRX's Avatar
I ended up putting the dash in and then having the bar come through the vents. I didnt have to run a dash bar because in NHRA, as long as you dont modify the firewall, you dont need the dash bar
THECRX
04-25-2014 12:36 PM
grass
04-05-2010 11:45 PM
xsellxoutx
11
12-29-2003 09:46 AM
dustin
11-12-2001 01:37 PM
Quick Reply: CRX Roll cage
