93 accord replaced steering rack and pump, still no PS, SOS!
Old 04-16-2014, 07:04 AM
Jeepguywithonda's Avatar
Default 93 accord replaced steering rack and pump, still no PS, SOS!
I'll try to sum up this issue from the beginning and the actions I have taken. I bought a 93 accord as a fuel saver and I immediately noticed that the power steering seems very stiff at highway speeds but mostly normal around town. I was getting a hydraulic skreetching sound coming from the rack.
I replaced the rack with a remanufactured one from oreillys. The treads into the pump on the first rack I purchased had been stripped by someone or in the reman process. Got new rack, installed it, topped of reservoir, turned wheel back and forth, started the car to continue bleeding and noticed i was sucking air. Tightened the lines into the rack and leak was gone... So was all circulation of fluid through the system. Tried to bleed it for at least an hour and never got a bubble of air out.
I then cracked the pressure line from the pump loose to see if there was any fluid moving trough the system. Fluid did push out but not with much pressure. The air that entered the system did appear in the reservoir bottle. I replaced the pump and still have no power steering after another hour of trying to bleed it.
I have heard that these gen 4 accords have variable assist power steering, controlled by a sensor on the trans but there no wires to the pump or rack so I dont know how that could work. Maybe the reservoir bottle has a blockage?? Maybe oreillys sold me a second junk rack?? I am using honda spec PS fluid.
Any insight would be greatly appreciated as I am at a total loss on this one.
Car is a manual trans
Old 04-16-2014, 01:28 PM
holmesnmanny's Avatar
yes they do have speed assist .. which means the steering is designed to stiffen up steering at higher speeds ... completely normal
Old 04-17-2014, 06:53 AM
Default Re: 93 accord replaced steering rack and pump, still no PS, SOS!
I do now know that the stiffening at highway speed is normal, but the skreetching from the rack wasn't. Any idea how that system works with no wires to the pump or rack? I'm really thinking that is causing my problem because there is no noise coming from the system at all. If there was a blockage keeping me from having power steering I would expect alot of noise from the pump
Old 04-17-2014, 09:07 AM
NerfGunner420's Avatar
CLOGGED LINES
Old 04-17-2014, 09:36 AM
Have you experienced this due to clogged lines? Any suggestions how to unclog them other than start tearing all the lines off and replacing them?
Old 04-17-2014, 11:01 PM
If you have no power steering I would first look at the power steering pump. It's about $15 for a rebuilt kit and they are fairly easy to install. Keep in mind the pulley bolt is reverse threaded...lefty tighty, righty loosey.
I would guesstimate the speed sensor connector controls the opening and closing of the solenoid for speed assist.
Old 04-18-2014, 06:29 AM
I have already tried new pump, made absolutely no difference. Thanks for the comments though. I will post what the cause and repair end up being when I figure this out someday.
Old 04-28-2014, 11:10 AM
It was the rack. The one i purchased was defective
Old 04-29-2014, 02:59 AM
hondamark35's Avatar
wow, two crap racks from O'reily's! did they give you a hard time when trying to return them?
FMohlmann
11-18-2016 12:28 PM
76 camaro car
03-15-2016 03:25 PM
stinkfoot
01-20-2014 05:22 PM
radeonboy
10-12-2007 07:14 AM
deftyes
11-13-2006 04:10 PM
Quick Reply: 93 accord replaced steering rack and pump, still no PS, SOS!
