Doctorakes EJ6 J32A2 build/restoration
#26
If you loved me, you'd all sell me your magic cards to me today
Re: Doctorakes EJ6 J32A2 build/restoration
#27
Tonight I couldn't get the crown nut off the driver side lower control arm so I continued the PB Blaster regime.
Continued on and disconnected parts of the wiring harness on the passenger side, some grounds, fuel line, fuel return, brake booster, and some other hoses and grounds.
Started to pull the radiator when I discovered the bolt holding the bracket to the support was pretty much round and rusted.
At this point I decided time for fun so I grabbed my Dremel and grounf it off most of the way then just knocked it off. Power tools and sparks woot!
Called it a night after an hour or so and will continue on tomorrow.
And you could clean up that intake and sell it to some rice punk for like 25 bucks.
#28
all the parts are getting cleaned up and sold, dremel was sitting right there so I grabbed it and it did the job quick.
#29
no one wants to hear the truth
Are you going to keep it vsm? One of the best oem honda colors imo
good luck with the build.
#30
#31
Small amount of work last night, everything except the mounts, linkage and driver side axle is disconnected from the engine. Early next week I hope to pull the engine.
Exhaust disconnected from the header.
#33
No clue on the actual mileage, ex cluster says 265 and PO told me that was correct. I will carfax it when I have a chance.
The body work is going to be an adventure, I have never done any in my life.
#34
Better get the welding equipment and angle grinder out if you want it done right. Dont use a rivet gun and bondo like i did.
#35
#36
Busy Easter weekend out of town. Took off today and finished pulling the motor, now I can start cleaning the bay up.
#37
Got the whole front half of the bay removed of everything, this weekend I will get the rest out.
Sorry JoeBlue, selling the swap to my buddy for one hell of a deal. I will have other parts available at some point.
No pics, but before the weekend is up I will have some.
#39
#40
#41
Small update.
Picked up a welder today for the body and engine bay work, plus maybe future projects.
Worked on cutting out the spot welds on the front end, used a spot weld cutter I just got in the mail.
And I finished pulling the harness out, the thing was hacked to death so I cut some of it out, I doubt I will be able to salvage much.
#43
#45
#47
Anti-GDD White Knight Simp
Respect the J series swap
Finally, a build on here interesting enough to entertain me while I'm away from mine....
But where are the updates?
#48
I am hoping next week to get back to work. Selling the wifes car and buying her Vette took some time away from my project.
