Lighting HID/Xenon kits, Retrofits and Associated Topics
Lights flicker/pulse... at a loss
Old 03-13-2014, 06:13 PM
eXpo's Avatar
Default Lights flicker/pulse... at a loss
1995 LX Civic.
I initially noticed my tail lights and license plate lights would flicker/pulse continuously. Then realized my interior lights (every light) flickers/pulses also.
I checked the fuse under the dash and all is good there.
Then I realized that my headlights and city lights flicker/pulse too (not on same fuse as other lights). So then I began to think that maybe it's my alternator on it's way out.
Tonight I went to leave work, lights were flickering. It was a little cold outside so I slid my climate control fan speed from "Off" to "1", rpms dropped for a split second and the flickering slowed down, rpms returned to proper idle. Then switched to fan speed "2" and all lights instantly stopped flickering/pulsing completely.
I am at a total loss on what is going on and why it is doing this. I haven't checked my alternator yet, but the fact that the fan speed "solves" the problem is very odd!!
Any input/insight on this?
Old 03-14-2014, 06:45 PM
Ulland's Avatar
Default Re: Lights flicker/pulse... at a loss
I had a problem like this in my 2000 Subaru forester and I replaced the battery thinking that was it and 2 days later was still having trouble even with the optima battery I purchased. Went to my local parts store to have my alternator tested and found out I was running on only battery. So I would have your alternator tested. Hope this helps resolve you issue.
Old 09-29-2014, 10:33 AM
OG Wagon's Avatar
Also, check your grounds! and Battery Terminals to make sure they are good and tight.
sweux
08-05-2017 06:02 AM
NatedoggAZ
02-10-2006 11:00 AM
Quick Reply: Lights flicker/pulse... at a loss
