Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Sometimes long (really long) crank time, 2005 Acura TL
Old 02-26-2014, 09:35 AM
TLdriver's Avatar
Default Sometimes long (really long) crank time, 2005 Acura TL
2005 Acura TL
Body: SD
Mileage: 193,000 granny-like freeway miles
Vin: 19UUA66255A049417
Problem: Long crank time, no other problems.
My 2005 Acura TL has always been hard cranking, maybe like 3-4 cranks then vroom. A really nice battery killer so thanks Honda, however like many other people I have always dealt with it. But recently it occasionally takes a really long time to crank, like 10 sometimes 20 cranks. It hasn't failed to start yet, but it does this randomly (cold,hot,warm...etc) about every other day, and I start it maybe 4 times a day. It seems to be getting worse over time. Its little long crank episode seems to add a couple cranks each month. The other day it took about 20 cranks, then started, but made a slow rumble almost like it was going to stall. So I think its only a matter of time before either my battery dies from this, or this problem becomes worse.
The dealership can't find the problem, but the great news is that they keep taking my money YAY!
The "fuel pump relay" was replaced in 2007 by recall (so they told me). So I don't think that is the problem.
The battery was replaced, so that is not the problem.
A freekin blue tooth module in the steering problem was replaced by the dealership to address this issue, nope didn't work.
Its current on its maintenance and tune-ups.
I did some research on the internet and seen a few possible fixes. But I wanted to run it by the world first.
The fuel pump. Thots? How much might that cost? Is it worth trying this?
The "fuel pump regulator". What is this, is it the same as the fuel pump relay? If not, how much and is it worth replacing?
The oxygen sensor. Thots? About how much and is it worth replacing?
Is there anything else it can be?
Old 03-03-2014, 06:15 PM
kouajones's Avatar
Default Re: Sometimes long (really long) crank time, 2005 Acura TL
Service Bulletin 05-013
Safety Recall: Fuse Box May Cause a No-Start or Stalling Condition
A loose terminal in the under-dash fuse/relay box may cause the fuel pump to lose power. If the fuel pump becomes inoperative, the engine may not start. In the worst case, if the fuel pump loses power while driving, the engine could stall without warning, and a crash could occur.
Applies To: 2005 TL – From VIN 19UUA65..5A012670 thru 19UUA65..5A013543 From VIN 19UUA66..5A012008 thru 19UUA66..5A015591
Old 03-03-2014, 06:17 PM
kouajones's Avatar
VIN 19UUA66255A049417 PDI Dealer 251105
Model TL PDI Date 05/03/2005
Model Year 2005 Demonstrator Date
Engine No. J32A32053826 Delivery Date 05/08/2005
Emission Type KA Mileage at Purchase 10
Selling Dealer 251105 AUTONATION ACURA STEVENS CREEK
Owner Information
Original Owner WILLIAMS Current Owner WILLIAMS
Warranty Extension / Cancellation Information
Factory Extension - No. of Miles
Factory Extension - No. of Day(s)
Factory Extension Warranty Type
Warranty Cancellation Date
Campaign / Recall Information
06-050: Vaugn Class Action Acura
07-017:C 05 ACURA FUEL PUMP RELAY
08-013:C 04-05 TL WIPER MOTOR
08-016:C 04-08 TL POWER STEERING HOSE
Accessory Audio Information
Original Radio Serial No. Original CD Serial No.
Replacement Radio Serial No. Replacement CD Serial No.
Radio Part No. CD Part No.
Vehicle Service Contract (VSC) / Acura Certified Pre-Owned Vehicle (ACPV)*
VSC No ACPV No
Old 03-22-2014, 09:42 AM
TLdriver's Avatar
*** bump ***
Thanks for the bulletin, that part was already replaced.
So I may just have the fuel pump, fuel pump regulator, and oxygen sensor replaced. But I need to know if these are all different parts, or part of the same part...etc.
Can someone please advise?
Old 03-26-2014, 07:39 PM
kouajones's Avatar
So, You said that the "Driver Side Fuse Box assembly have been replaced?" I am talking about the Fuse Box. Not the fuel Pump relay. The bulletin that shows up on your VIN status only has the Service Bulletin 07-017. There is another Service Bulletin 05-013 which calls for the replacement of the "Fuse Box Assembly. If the fuse box have been replaced then disregard this post. I apologize for wasting your time.
Old 11-25-2016, 10:46 AM
TLdriver's Avatar
Sorry to revive (my) old thread, but its relevant. So I never did get the hard start resolved, and now it has developed a rough idle and the check engine light is on. It also shudders once in a while, like when driving down the street the car looses a tiny bit of power off and on for a couple seconds but not enough to stall or even slow down. I am taking it to the shop tomorrow to get looked at.
kouajones posted my VIN info above...
Question:
1. Is the recall information above fixes already performed on the vehicle or is that just general recall information? I may ask the mechanic to verify that the relay was replaced. And also check the fuse box.
2. what else do you guys think this could be? I am worried about getting more stuff fixed which I don't need only to have the same problems (again).
Acuralovin
05-20-2016 04:40 PM
SeanRK
Honda CR-V & Element
12-08-2015 04:12 PM
03ep3sicivic
06-28-2009 08:05 AM
Quick Reply: Sometimes long (really long) crank time, 2005 Acura TL
