2001 acura Integra no start
when i was leaving school today i got into my car pushed the clutch in and turned the key nothing happened the radiator fan turned on an started spinning. I was able to push start it but when i turn the key nothing happens, but then later i could start the car with the key and now the key wont start the car but i can push start it. when i was driving like this my temperature gauge was jumping around a lot. im leaning towards the starter or the ignition switch any ideas
Old Fart
Re: 2001 acura Integra no start
Start by redoing your main grounds, [batt. to chassis/chassis to engine/VC to rad support/thermostat grounds].
Then next time, [if above does not solve problem] it will not crank do a bypass jump to narrow down the problem.
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/ 94
sometimes it will turn over and crank most of the time it does nothing im going to do the bypass jump tonight and inform you my results.
