only cylinder 4 firing
Old 02-20-2014, 12:42 PM
bodenman's Avatar
Default only cylinder 4 firing
I have an ls vtec fresh build just put in
I've gone through the timing and everything is good I checked spark on all plugs and there all good strong white spark. The injectors are all working . I'm stumped I did a compression test cylinders 1 2 & 3 the ones not firing are giving a cold reading of 160psi the cylindis r that fires gave 210psi not sure if this is a valve issue. When I pulled the plugs they were wet with fuel the one from cylinder 4 is black like it's running rich.
I have only a cel 21 for my vtec not wired up yet i turned vtec off at the ecu
b18a1 block
b18c1 head
p72 s300 ecu
Old 02-20-2014, 12:48 PM
carlos8's Avatar
Default Re: only cylinder 4 firing
If you have strong spark and fuel but a weak compression on this 3 cylinders.
Did you lash the valves after build the engine?
Perform a leak down test. to see the results in this cylinders.
Is the car TUNED?
Old 02-20-2014, 12:49 PM
Hysterically Calm
TomCat39's Avatar
You can do a leak down test to rule out valve issues, or verify them for that matter.
Old 02-20-2014, 02:15 PM
bodenman's Avatar
it isn't tuned I have an ls vtec basemap it should at least start the engine I think it is getting too much fuel and ignition timing is off I couldn't find my leak down tester so im gonna go buy another one tomorrow
if that comes out ok then im gonna remove some fuel like minus 10% from fuel trim and try moving the distributer around
Old 02-20-2014, 02:17 PM
bodenman's Avatar
with the 3 plugs that aren't firing being wet when I pulled them but I have solid spark and the one that does fire being black that's what I was thinking anyway
also it does pop and sputter when cranking leaning towards ignition timing being wrong
Old 02-20-2014, 02:21 PM
TripleLude's Avatar
Spark plug wires in the right order for your distributor?
lol just watch and see...
Old 02-20-2014, 04:35 PM
Fish Twig
tony_2018's Avatar
I don't think the tune has anything to do with the cylinder pressure. I vote leakdown test as well and also do a valve lash adjustment.
Old 02-20-2014, 04:36 PM
Fish Twig
tony_2018's Avatar
The title threw me off because there is no way it can only fire in cylinder 4 and not the rest.
Old 02-26-2014, 02:15 PM
bodenman's Avatar
the problem was timing the timing belt cover wasn't on right and is deformed so the timing belt was set a notch off I found true top dead center with a dial indicator and marked the cover and re did my timing and starts right up thought I would share
Jake Pierson
11-24-2018 07:53 PM
213374U
03-10-2009 06:22 AM
Streetracer4life128
07-02-2006 03:12 PM
mr_mbuna
08-12-2003 06:33 PM
Quick Reply: only cylinder 4 firing
