h22 with mahle 9:1, what should compression be?
Old 01-20-2014, 12:44 PM
tjmutlow's Avatar
Default h22 with mahle 9:1, what should compression be?
Just tested my pistons, showing about 150 across the board. Is it ok? Just replaced head gasket.
Old 01-20-2014, 12:50 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: h22 with mahle 9:1, what should compression be?
That's extremely low. What motor are these pistons in?
Old 01-20-2014, 01:51 PM
hardcore97's Avatar
Just gonna take a shot in the dark and say h22...
Old 01-21-2014, 04:55 AM
shawty22's Avatar
^^Haha
Static compression depends on a lot of things. Cold vs Warm. Size of Cams. Cam timing. Bore size. Ect. I dont have a lot of experience with H22s, but those are some ideas to think about.
Old 01-21-2014, 08:56 AM
NotARaCist's Avatar
Right, and if I had read the title and not just the thread, I would have realized that
OP, 150 is still low. 180-200 would be more acceptable. Did you do this test WOT on a warm engine? Did you follow up with a wet test?
Old 01-22-2014, 09:43 AM
Finest's Avatar
The obvious question: WHY did you have to replace the headgasket in the first place?
Jago
06-29-2006 02:31 PM
93H22ACX
08-25-2004 02:20 AM
meanEG
23
12-24-2003 10:28 AM
DSGB.
12-24-2001 08:55 PM
Quick Reply: h22 with mahle 9:1, what should compression be?
