ZC means 1.6L D series
Old 12-30-2013, 09:19 AM
Tyson's Avatar
Default ZC means 1.6L D series
its important to educate people on the differences and vagueness of the term "ZC" in order to communicate properly.
ZC = "d series, 1.6L" thats it.
it includes:
-1.6L SOHC carburated (JDM only, most common ZC imported so far, look for an opening or plugged hole in back of head where the original mechanical fuel pump went thru, and extra lobe on camshaft)
-1.6L SOHC MPFI (THIS is the one that is nearly identical to the D16A6, but not 100%)
-1.6L DOHC D Series (the original imported DOHC "ZC")
-1.6L SOHC VTEC D Series (similar to D16Z6, not as commonly imported. most common imported is 1.5L D15B VTEC, which is not a ZC, obviously)
does not include:
-1.6L DOHC VTEC (that would be a B16 which is totally different B series)
-1.5L SOHC VTEC D series
-1.5L anything
Old 12-30-2013, 09:22 AM
Tyson's Avatar
Default Re: ZC means 1.6L D series
original page info here.
sorry, original links to honda arent valid anymore. not sure if anyone saved the pages. if you have the original pages, please forward it to me. had lots of specs.
JDM ZC Sources
1984-1987
DOHC ZC MPFI 9.3 CR 135 ps / 6500 RPM (Integra Gsi, Rsi, Civic / CRX Si)
DOHC ZC Single CARB 9.3 CR 115 ps / 6500 RPM (Integra ZS, LS)
DOHC ZC MPFI 9.3 CR 120 ps / 6500 RPM (4dr Integra Gsi)
DOHC ZC SINGLE CARB 9.3 CR 100 ps / 6500RPM (4dr Integra & hatch GS, ZS)
1988-1991
SOHC ZC DUAL CARB 9.1 CR 105 ps / 6300 RPM (Integra ZX, RX)
SOHC ZC MPFI 9.1 CR 120 ps / 6300 RPM (Integra RXi, Txi, CONCERTO)
DOHC ZC MPFI 9.5 CR 130 ps / 6800 (CIVIC/CRX Si) DYNOS
1992-1995
SOHC ZC DUAL CARB 9.1 CR 105/6300 (PS/rpm) (Integra ZX)
SOHC ZC MPFI 9.1 CR 120/6300 (PS/rpm) (Integra ZXi)
SOHC ZC VTEC MPFI 9.2 CR 130/6600 (ps/rpm) (Domani Vi)
DOHC ZC MPFI 9.5 CR 130 ps / 6800 RPM (Civic Ferio RTSi and Special Edition Civic Si) DYNOS
1996-2000
SOHC ZC MPFI 9.4 CR 120ps/6400 RPM (Integra)
Old 12-30-2013, 09:25 AM
Tyson's Avatar
no text
Old 12-30-2013, 09:28 AM
PHANTOM MENACE
24TEN's Avatar
Thank you for posting this, I hope EVERYONE reads it. Now can you make one for the "D15B" since everyone uses that term just as loosely?
I'm halfway serious on that last part.
Old 01-01-2014, 11:43 AM
pimpwagon's Avatar
D15b vtec as in d15z7? 3 stage vtec? Yes thare's alot of confusion with this too. better to include the actual engine codes and break them down that way. But a good start!
Old 01-21-2014, 09:49 AM
Tyson's Avatar
you guys can write a "D15B" disambiguation thread.
i meant it in a general term and dont really care about 1.5L engines.
Old 01-21-2014, 10:35 AM
89ED's Avatar
within the last year ive seen now 3 ZC blocks with dpfi systems. the last two i saw a week ago at the junk yard. both were sedan LX models. the first i saw was an EX sedan.
Old 01-21-2014, 12:00 PM
Keyboard Humorist
4drEF's Avatar
^^ I hope somebody just rebadged that sedan with the 'EX' logo.
They would have had to have done an MPFI to DPFI downgrade and added a ZC block into the mix as well.
EX -only- came with a 1.6 MPFI. Manual or auto trans - still got the 1.6 MPFI.
Old 01-21-2014, 02:27 PM
Tyson's Avatar
doesnt really matter.
these ZC come in with whatever fuel delivery, and the original DPFI or MPFI manifold gets thrown on.
so... like... so what...?
Old 12-18-2015, 09:40 AM
bhacek's Avatar
i have ZC dual carb integra zx, and planing to swap b20vtec. so i need information what mount swap i need? is it D to B series?
thanks... and
Old 12-18-2015, 03:26 PM
jdmboyef9's Avatar
ZC's typically use the same mounts as the sohc. That being said you will need custom B series mounts. Your next biggest hurtle will be converting from carb to fuel injection. It is not as simple as just the wiring. My understanding is the entire fuel system is different.
Old 12-19-2015, 10:16 AM
bhacek's Avatar
YES, that's correct, the entire fuel system is totally different, local workshop says that too. i assume its not worth the money to build B20vtec in integra ZX..
but but but i love the car its rare car in my country.. just to bad i got DA5, not DA6..
i think i just need to original restore..
Old 10-21-2020, 01:41 PM
Tyson's Avatar
2020 bump. info hasnt changed, unfortunately the honda.jp links are dead.
Old 10-21-2020, 03:11 PM
Efmysedan's Avatar
Can a TD02 be repinned so that it works with a P28???
Old 10-22-2020, 04:09 AM
DaX
DaX's Avatar
Wrong thread for this question, but the answer is no. The TD02 is designed to work with OBD0 computers and provides 16 pulses per revolution for crank position. The OBD1 and OBD2 distributors provide 24 pulses per revolution for crank position.
Old 03-11-2022, 05:44 PM
jteuscher20's Avatar
I recently bought a 90 hatchback civic with a non-vtec dohc zc motor and all I’ve found about it is this thread of you referring to it as the originally imported zc motor.. any chance you can point me to a engine code location? I’ve tried the serial number with no luck.. just trying to figure out if it’s the motor I think it is
Old 03-12-2022, 12:25 AM
Tyson's Avatar
The point of this thread is that there is no engine code on ZC stamped engines.
What color is the DOHC valve cover? Black or brown?
Old 03-12-2022, 07:55 AM
It is black, very very faded black haha
Old 03-12-2022, 02:58 PM
Old 03-15-2022, 11:32 AM
PHANTOM MENACE
24TEN's Avatar
It is the "black top" or "3rd gen" version. Aside from the "black" valve cover, the easiest way to distinguish is by the valve cover, the Honda H is over the exhaust cam and the valve cover bolts are on the outside/perimeter of the valve cover where as the older version had 4 bolts going through the middle (over the cam caps).
jaydmef8
20
06-13-2006 08:48 PM
h22_crx
13
10-18-2005 08:40 AM
jdmef90
16
09-07-2005 08:13 PM
bazookatooth
02-10-2005 12:20 AM
Mr.c
13
06-14-2004 06:54 PM
Quick Reply: ZC means 1.6L D series
