D16Y8 Head/D15B7 Block -Would d16y8 nippon racing piston (75.5mm) fit in d15b7 block?
Old 12-17-2013, 09:15 AM
Aykayek's Avatar
Icon3 D16Y8 Head/D15B7 Block -Would d16y8 nippon racing piston (75.5mm) fit in d15b7 block?
Im gonna do a mini swap on engine. A d16y8 head with a d15b7 block question is that would d16y8 nippon racing piston(75.5mm) fit in the d15b7 block. It say's it will but just trying to make sure.
Old 12-17-2013, 11:56 AM
PHANTOM MENACE
24TEN's Avatar
Default Re: D16Y8 Head D15B7 Block
It will physically fit if you have the block bored out for that size. Do you understand what that process involves?
Old 01-06-2014, 10:58 AM
Aykayek's Avatar
Default Re: D16Y8 Head/D15B7 Block -Would d16y8 nippon racing piston (75.5mm) fit in d15b7 bl
Yeah I do know what it involves
Old 01-06-2014, 11:27 AM
B_Swapped93's Avatar
major waste of money for zero gain virtually just throw a b20 in there....
Old 01-06-2014, 12:30 PM
Hysterically Calm
TomCat39's Avatar
The whole point of the mini ME mod was for a cheap inexpensive way to get a bit more power and vtec.
The most I would do is Magneflux Dye test the rods then shotpeen them to remove imperfections that can cause stress fractures.
That's only a few hundred bucks and gives you a bit more reliability with the higher RPM on toothpick thin rods.
Don't waste your money on trying to "build" the block, it's just not worth it.
You are going to spend enough tuning it being the Y8 doesn't run the same as a Z6 so really should be tuned, while the Z6 can be plugged and run with a P28 with little to no effort.
Old 01-07-2014, 05:51 AM
Aykayek's Avatar
Oh okay so if I ran the z6 bottom block it would be and the y8 head only becuase I'm ob2 and really don't want to go ob1 and gonna buy the AEM Tru-Time Adjustable Cam& aslo Brian Crower Stage 2 so why not Valvesprings & Retainers aslo? lol and just try to boost 10 psi of boost on a tune and dyno after it's all said and done motorwise.
Old 01-07-2014, 07:42 AM
purgat0ry's Avatar
Tuning on ODB2 isn't really ... reliable nor easily possible.
DO you have goals or just "Build for some arbitrary number I pulled from the sky"?
Old 01-07-2014, 09:08 AM
Aykayek's Avatar
Well I mean I haven't had a probably so far with my current tune with a all stock block d16y8 with injectors and fuel pump and 7 psi and ahhahhha nahh I just don't wanna do some crazy 600 plus type deal I wanna at least hit the 300 or get as closest as I can you get me?
Old 01-07-2014, 09:13 AM
purgat0ry's Avatar
Take your money, walk up to a tall building, take the stairwell to the roof, make it rain.
That's what your doing without proper plans and knowledge aside from "nahhh man, I want a faster car than an econobox using econobox parts"
Old 01-08-2014, 01:16 PM
Aykayek's Avatar
Okay so in your eyes what would be the "proper" way to build a mini me swap? Besides this massive write up? https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-d15-sohc-vtec-mini-me-massive-write-up-56k-goodbye-554053/
Old 01-08-2014, 01:43 PM
not waste several hundred for boring and balancing the rotating assembly, for maybe 5whp...not even. I could gut a dx sedan with a Y7 and still beat you....
Old 01-08-2014, 02:30 PM
Aykayek's Avatar
The thing I dont get is that I've raced and won against b16a2 jdmb16a b18 and a b20(but lost from a DIG) 2 v6 ford mustang all while in a d16y8 ". So why would I wanna go to a b20 if I beat them? just a fyi I already got the z6 block so Ill be using the bottom block.
Old 01-08-2014, 03:23 PM
Marvin1985's Avatar
Build your z6 block and slap a stock y8 head if you want then boost it to 250~ whp and DD it. It'll cost a bit more than a b swap tho but if you want a sohc turbo then go for it. You'll need injectors 450cc and a tune on obd1. About $3000 if bought semi used
Old 01-08-2014, 03:30 PM
I'm guessing you own an eg hatch, most likely gutted lets see the dyno sheet ? or did you just base map it...
Here's my b20V...think you could beat it ? DC2 chassis gutted and caged + areo components. 2371lbs curb weight.
Old 01-08-2014, 03:38 PM
Sccacivic1997's Avatar
Oh sexy :-)
Old 01-09-2014, 08:07 AM
Aykayek's Avatar
Pretty nice b20 and you will probably beat me I'm not gonna sit here and lye and bullshit but never dought a single my man.
raider1qaz
02-01-2014 06:09 PM
Aykayek
12-30-2013 04:13 AM
theslugbug
05-21-2008 11:01 AM
lmiguelvv
04-14-2004 11:21 PM
Quick Reply: D16Y8 Head/D15B7 Block -Would d16y8 nippon racing piston (75.5mm) fit in d15b7 block?
