ECU Pinouts
ECU Pinouts
I am unable to understand following Pins.
A2 MCS
A3 2WBS
A4 VSV
A5 CRS (may be cruse control solenoid)
A6 PCS
A9 VSSOUT (does it goes to cluster?)
A28 SLU
A2 MCS
A3 2WBS
A4 VSV
A6 PCS
A28 SLU
Re: ECU Pinouts
What is this for? Year, model, trim & engine?
A2 = Engine mount control solenoid valve.
A3 = Drives EVAP bypass solenoid.
A4 = Drives EVAP control canister vent shut valve.
A5 = Cruise control signal.
A6 = Drives EVAP purge control solenoid valve.
A9 = Could go out to a junction box, that sends a signal to the cluster, cruise control and A/C... I'm not 100% sure as you have not listed what vehicle this is for.
A28 = Detects interlock control unit signal
Re: ECU Pinouts
If your car is originally an obd1 car and you're using an obd2 ecu then you need to have a crank sensor and crank timing pulley for an obd2. Do you currently have one of both installed?
hotair
11-24-2013 01:34 PM
tr0n9h
10-30-2007 04:46 PM
