Kraftwerks D-Series Race Supercharger Kit
Old 08-27-2013, 07:37 AM
skunk2.com's Avatar
Default Kraftwerks D-Series Race Supercharger Kit
The D-Series Race Kit is based off of the impressive Rotrex C30-94 supercharger. The D-Series Race Kit produces impressive results throughout the entire power band due to its patented traction drive technology. And, unlike any other forced induction system, this kit provides a linear power curve, torque on demand, and cooler operating temperatures
The D-Series Race Kit provides instant throttle response and a progressive power curve that increases all the way to redline without the typical 'spiking' or 'surging' associated with turbochargers. This unique, more useable power curve results in reduced cylinder pressures, less strain on engine components, and increased reliability. Rotrex superchargers also operate much cooler when compared to turbochargers and other supercharger systems, which reduces the engine’s intake air temperature as well as its risk of detonation.
Rotrex superchargers are renowned for their compact size, high adiabatic efficiency, low vibration, and quiet operation. Their unique traction drive technology is what makes all of this possible, which, unlike other superchargers, transmits power through frictional forces between its rolling elements. Each Rotrex unit features its own self-contained oiling system that remains independent of the engine. Its dual-action oil pump supplies traction fluid to the supercharger while the supplied cooler ensures proper fluid temperatures at all times.
The D-Series Race kit fits D16A, D16Z, D16Y, and the JDM D15B. This kit does NOT include any type of piping, intercooler, or fuel management.
Kit Includes:
• Rotrex C30-94 Supercharger w/ 120mm Pulley
• Rotrex Self-Contained Oiling System
• Oil Cooler
• High-Quality CNC-machined Brackets, Idler Pulley, and Tensioner
• High-Quality Metric Fasteners and Hardware
• Silicone Air Inlet Elbow
• Double Sided Drive Belt - Works off Stock and Aftermarket Pulleys
- Kit REQUIRES Custom Fabrication for Intercooler + Piping and Engine Tuning
- Kit REQUIRES removal of A/C Compressor and Power Steering
- Kit REQUIRES header that has narrow pairing
- Kit is NOT CARB Approved, and is never to be used on Pollution Controlled Vehicles or Public Highways
*Total Horsepower will be determined by the engine type and build. The total horsepower depends on engine modifications, tuning, weather, altitude, etc. (Typically 250+ hp)
*Recommended Modifications:
- Upgraded Clutch
- Grams Fuel Injectors
- Grams Fuel Pump
Part Number: 150-05-0030D
http://cms.kraftwerksusa.com/id/947/...er-Kit-C30-94/
Old 08-27-2013, 10:38 AM
mitsuman's Avatar
Default Re: Kraftwerks D-Series Race Supercharger Kit
Any completed installs? Dyno sheets to back up claims?
What's up with that engine bay shot? Does not look very professional and does not make me want to buy this kit. I really think you would benefit from removing that picture and leaving just the kit until there is a more complete install available. Not one with tools hanging around, install incomplete, header hanging off the head, dip stick hanging out by the fender...
Old 08-27-2013, 11:42 AM
RACEPAK's Avatar
PRICE?
Old 08-27-2013, 11:47 AM
92cxyd's Avatar
http://store.kraftwerksusa.com/super...t-compact.html
Says it is on back order, and it $2.8K, for that much I built two complete s/c systems with ic piping and all.
Old 08-27-2013, 12:06 PM
RACEPAK's Avatar
true that!
Old 08-27-2013, 12:18 PM
skunk2.com's Avatar
It's just a quick shot! The picture provided is simply to give you an idea of how it mounts and where it is situated in the engine bay. Those that are interested in the kit should be able to look past some tools, and an OEM exhaust manifold.
Originally Posted by RACEPAK
PRICE?
The kit is $2795.00 and SpeedFactory is currently doing a group-buy on the B and D Kraftwerks kits... They are offering about $500 off.
The store has been updated and they are IN-STOCK. You could build two Rotrex based kits with intercooler piping for $2.8K? Hook Kraftwerks up with whoever you are getting your Rotrex units from!
Old 08-27-2013, 01:19 PM
mitsuman's Avatar
You're promoting a new product, I figured maybe you would want to start it off properly. I don't care about the stock manifold, but it's not bolted up! It just looks sloppy and poorly thought out. Hoepfully this is not a representation of the kit.
This is a close to $3,000 unit; it deserves a little better representation, backed up with some factual data.
Old 08-27-2013, 01:31 PM
skunk2.com's Avatar
We'll take it down for you, but we'll send everybody who complains about not seeing how it bolts up your way. Cool? If you know anybody that has a clean bay, a nice header, with a D-Series motor, send them our way!
Old 08-27-2013, 01:40 PM
92cxyd's Avatar
LOL I did not say it Rotex s/c I was using.
Old 08-27-2013, 01:46 PM
mitsuman's Avatar
I'm just trying to help man. Not busting your ***** for the sake of busting your *****.
You might find some guys willing to help out on D-series.org
Old 08-27-2013, 03:48 PM
EFSedan#6's Avatar
I'll be a test mule. haha. I will gladly remove my JRSC...for this.
Old 08-28-2013, 08:43 AM
H-T White Ops
Frozen E's Avatar
Fail Boat!!!
Old 08-28-2013, 11:03 AM
Loafin''s Avatar
If you guys were a few months later, I'd have my RT4WD Wagon available.
Currently building an A6 for turbo.
Old 08-28-2013, 08:01 PM
GraphiteAcc0rd's Avatar
3K...and no dyno numbers.
Yep, usual junk2 style.
Old 08-28-2013, 10:25 PM
D Tranny Guru
Mista Bone's Avatar
So it took 10+ years for someone to figure out the belt routing due to the Rotrex unit spins in the wrong direction.
AKSC v2.0
Old 08-29-2013, 10:04 AM
HiProfile's Avatar
Any idea on boost pressure?
I was doing some VERY rough calc's with poor info I found on pulley diameters, as well as looking at Rotrex PDF's. I'd guestimate at 7500 engine rpm the C30-94 will spin ~5300rpm, or internally at ~50,600 rpm. I'd presume it will work out to over 15psi.
I'm also curious why the C30-84 wasn't used. That seems to have a better sweet spot & surge line for the D16. I can only presume because it's used on all the other kits?
Old 08-29-2013, 10:28 AM
skunk2.com's Avatar
Contact Kraftwerks at support@kraftwerksusa.com
You could still build the wagon with plans to use the supercharger kit.
AKSC v2.0
It surely did not take Kraftwerks 10 years to figure it out...
Old 08-29-2013, 10:53 AM
skunk2.com's Avatar
In the past Kraftwerks has tried to build kits with the smaller trim superchargers, only to find that 9 out of 10 customers requested the largest available which is why they went with that sized blower.
Old 08-31-2013, 07:03 AM
Hype-R Stalker
CleanLikeJdm's Avatar
Whats with all the stupid smileys? Does skunk2 have a teenage girl doing their advertising?
Old 08-31-2013, 08:19 AM
Moderator
TheShodan's Avatar
Its just a thread post.. Perhaps I need to mail out some of my old man's blood pressure medicine.
Relax. Is it really that relevant?
Old 09-01-2013, 07:21 AM
Hype-R Stalker
Originally Posted by TheShodan
I would accuse you of being said teenage girl for s2, but I won't be that mean
Old 09-05-2013, 06:44 PM
gordonng85's Avatar
is there anyone making a build of it with a D16? and dyno sheets?
thanks!
Old 09-05-2013, 06:59 PM
Moderator
TheShodan's Avatar
Like, I worry about that kind of stuff....
I like a lot of their stuff. Not everything, but a lot. Only the young cats born in 1992 and up feel that having their favorite companies introduce products is oh so bad..... That **** is funny to me , honestly.
Old 09-06-2013, 07:42 AM
amrodtech's Avatar
Its a nice kit which is different. Some people actually like that kind of stuff! I don't exactly see many Jackson Racing Kits rolling around these days.
Old 09-06-2013, 01:50 PM
GEN2 LS's Avatar
for good reason :p
Quick Reply: Kraftwerks D-Series Race Supercharger Kit
