Speedometer stopped working, engine light went on after driving it for a while
Old 08-10-2013, 07:12 PM
JustEFit's Avatar
Default Speedometer stopped working, engine light went on after driving it for a while
I was driving my car that has a first gen b16a swap, the speedometer stopped working, driving for a bit with out the odometer, the engine light goes on, I checked my ecu and it was throwing me 1 beep, then 7 fast beep, which I think it's a code 17, how do I fix this and get my speedometer working again?!?!?
Old 08-11-2013, 10:32 AM
Freemananana's Avatar
Default Re: Speedometer stopped working, engine light went on after driving it for a while
Code 17 is VSS, which means the portion on the back of the cluster has gone bad. It could be the portion inside the trans that has come undone or something. I'm not sure. But it's easy to replace the VSS on the back of the cluster, from what I've heard.
Old 08-11-2013, 12:23 PM
JustEFit's Avatar
So if I have a bad cluster now, do i just replace the cluster? I just recently took mine out and unplugged everything and plugged it back in, I heard it worked on someone, and hope it works for me. P.s I notice the cable not spinning when I jacked up the car and rolled it in gear, the cable located in the cluster area was not spinning at all? Something's not right, any ideas anyone?
Old 08-11-2013, 01:19 PM
Riceburner247's Avatar
If the cable isn't spinning on the cluster side, unplug the cable from the trans and see if the unit in the trans is spinning.
Old 08-12-2013, 09:17 AM
JustEFit's Avatar
I unplugged the unit in the transmission , and realized the cable has snapped inside of it, the housing for the cable was seized in the transmission, I have to pull it out hard, so what type of speedo can I use as a replacement?
jumpin4abeat
19
04-15-2017 01:02 AM
_EF9
04-21-2013 09:59 AM
red-eg6
07-05-2005 08:26 PM
Mach69
06-03-2005 06:50 PM
Quick Reply: Speedometer stopped working, engine light went on after driving it for a while
