rex b18a1 coolant temp guage not workin. also gas purges
Old 07-14-2013, 09:57 AM
jcr2013rex's Avatar
Default rex b18a1 coolant temp guage not workin. also gas purges
... ok I got 89 crx si with b 18a1..never overheated . but when I got it, it was a mess all around ...but I notice that when I got it the temp guage doesn't work... and when I drive on hwy.. it has like purges of more gas.. I can feel the car picking up .. If am right I think the coolant temp sensor also controls the gas... so I wanna get this right ... for a smooth ride...also when I got it the guy had a civic half radiator in it with the overflow tank blocked...(I changed it) and I think somethings blocked off the mani too... by the way I have plenty of good pictures just that me galaxy3 won't like copy the address... post your email I can send them to whom ever .maybe someone can post them for me thanks
Old 07-15-2013, 02:20 AM
jdmjunkieXL's Avatar
Default Re: rex b18a1 coolant temp guage not workin. also gas purges
check the 1 wire coolant temp sensor under the distributor wire color should be yellow/green make sure its connected if not chk the wire for continuity with a digital volt meter other end of wire should be under driver side dash
And the purges of gas??? Is it a stutter? Might wanna check to see if your tps is bad or out of adjustment
eazy64
10
02-16-2011 06:05 PM
tsmith0819
01-15-2007 01:20 PM
GreddyCivic7
05-20-2006 06:40 AM
Quick Reply: rex b18a1 coolant temp guage not workin. also gas purges
