Injector pulse..
Old 06-24-2013, 04:22 AM
anon191's Avatar
Default Injector pulse..
Hi guys,
New to the forum as I've just got a CRX-DelSol - UKspec.
Had the car a few days and it developed some interesting electrical faults preventing car from starting....
The car cranks, but doesnt fire.
The engine will fire on aerostart, but then dies.
It has good, constant spark.
Fuel pump runs.
Injectors have power (noid light tested, light stays on when cranking)
ECU is fine, tried a replacement.
ECU grounds are fine, ran them again just to be sure.
Continuity to injectors from ECU is fine.
Battery and fuel levels are ok.
The symptom essentially is no injector pulse to ground the injectors...
I've tried everything I can think of to get it to fire, but it still wont have it. I'm this close to burning the fu*ker at this point.
Does anyone have any ideas? - I was thinking possibly a crank sensor not sending pulse, but would that stop the engine firing?
Old 06-24-2013, 04:40 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Injector pulse..
Color of spark? Injectors actually spraying?
Old 06-24-2013, 04:45 AM
anon191's Avatar
Injectors spray when I manually ground them and the spark was a blue colour.
Old 06-24-2013, 05:18 AM
Former User's Avatar
How'd this happen? What work was being done?
What ECU - OBD0, OBD1 or OBD2?
A bad CKP sensor or circuit would prevent the injector pulses, but then there would also be no spark.
Old 06-24-2013, 06:23 AM
anon191's Avatar
It's a p28 ecu in obd2a. No work at all was being carried out. Just stopped working on my driveway...
Old 06-24-2013, 06:26 AM
Turn key off. Unplug ECU connector A. Check whether you measure continuity to body ground at pins A23 and A24 individually in the free connector.
http://www.phearable.net/tech/wiring...schematics.gif
Old 06-24-2013, 12:01 PM
anon191's Avatar
I'm getting 21 & 19ohms respectively. Are you sure the ecu is obd1, thought it was obd2..?
Old 06-24-2013, 12:24 PM
Post pictures of the ECU connectors. This should answer the question.
Old 06-24-2013, 12:39 PM
anon191's Avatar
ECU: http://postimg.org/image/729sawscd/
I tested the two black ground wires for continuity.
Old 06-24-2013, 12:58 PM
Hmmm...your P28 ECU does have OBD2a connectors. In this case, test A10 and A23 for continuity to body ground in unplugged ECU connector A. Both are black wires.
Old 06-24-2013, 01:03 PM
anon191's Avatar
Got 21 & 19 ohms on them.
Old 06-24-2013, 01:09 PM
I would recommend that you now try swapping in a known good ECU to see whether the problem is solved.
Old 06-24-2013, 01:14 PM
anon191's Avatar
Tried swapping in a good ECU, with the same generation etc....still had the same result.
Does a D16y8 have a crank angle sensor? Could that be related?
Thanks for the help, i really apprecate it.
Old 06-24-2013, 01:17 PM
Any CEL codes?
Old 06-24-2013, 01:21 PM
anon191's Avatar
Have one code: 41 - oxygen sensor heater?
Old 06-24-2013, 01:23 PM
Unplug ECU connector A and turn the key to ON(II).
Do you measure battery voltage to body ground at pins A11 and A24?
Turn key off. Do you measure continuity to body ground at pins A9 and A22?
Old 06-24-2013, 04:26 PM
Seagull Management
94EG8's Avatar
Yes, it's got a crankshaft position sensor in the distributor (CKP) and Crank Fluctuation sensor attached to the oil pump (CKF)
Thanks for the help, i really apprecate it.[/quote]
Unplug the primary O2 sensor and see if it starts. Normally it wont matter, but very rarely a bad O2 sensor can result in a no start condition.
Old 06-25-2013, 10:33 AM
anon191's Avatar
pins A11 & 24 both measure approx 12v with ignition on.
pin 9 is about 19 ohms and pin 22 is about 6 ohms - although the cable colour in the loom seems to be red and black not brown and black for pin 22?
Tried turning it over with no O2 sensor and still the same result...
B16Civic93
01-20-2014 04:30 PM
Gkdc182
10-22-2009 01:57 PM
KrispyKreme
01-04-2006 08:39 PM
jansenrw
11-19-2005 08:44 PM
Quick Reply: Injector pulse..
