Kidhuf 1993 ej2 build
Old 05-15-2013, 07:02 PM
Kidhuf's Avatar
Default Kidhuf 1993 ej2 build
Hey guys,
This is my 1993 Honda civic coupe Dx CDM model. I am the second owner of the vehicle bought it off a old lady who stored it in her garage for 12-years. It was covered in dust and needed some work to get it road worthy.
When I purchased it had 105,000 km on it I just rolled over 152k today. It has the stock engine which I just did the timing belt and water pump on. I have done some custom tasteful mods.
Tell me what you guys think here are some pics of the work I've done so far.
The most recent work was painting my rims, stripping the paint, sanding them down to metal, then sanding up from 200, 300, 400, 600, 800, 1000, 1500, 2000, wet sand, and the primer, paint, clear and mounted them. I unfortunately don't have any of the pics for that.
First I cleaned the dirty interior of the vehicle:
And heres what it looked like after shampoo, and vacuuming!
The second project, since it was in winter was painting the valve cover red:
The OEM paint that was on was super hard even with aircraft stripper!
Back to the metal
Taping it with precision
3 coats of VHT wrinkle red
Baked in my oven at 500 degrees, the house had a paint odor for days!
Finally mounted it back on to the engine sanded down the letters and walla!
I will update as I keep building.
Old 05-16-2013, 08:28 AM
canadaek's Avatar
Default Re: Kidhuf 1993 ej2 build
you sanded with 2000 grit then primed ? you could have stopped at 400 primed sanded with 600 then painted. you want some texture for the paint to stick to.
Old 05-18-2013, 04:43 AM
Kidhuf's Avatar
May 18th, 2013
Yesterday I retro-fitted a 99 Honda Prelude maplight into my ej2.
Measured first, traced checked again and then cut:
Ran the wires to the dome light and grounded it for power:
Finally the lights on, I put 2 LED's in and ordered a bigger one for the middle:
Sorry for the last crappy phone pic
Old 05-18-2013, 05:13 AM
Kidhuf's Avatar
I also retro-fitted power door locks on my ej2 because the Canadian models did not come with them.
First I went to the junk-yard to look for a switch I found one off of a Mazda Protege:
Second I took out the resistor:
I cut out my door panel:
I Inserted the lock switch and bolted it into the door:
This is the final product:
Old 05-18-2013, 08:10 AM
Mimo46564's Avatar
One of my Fav cars
I like how you keep the OEM look in everything you create
Old 05-18-2013, 08:51 AM
Kidhuf's Avatar
Originally Posted by Mimo46564
One of my Fav cars
Thanks man I appreciate it, lots more updates coming soon.
Old 05-26-2013, 03:29 AM
Kidhuf's Avatar
May 26th, 2013
Hey guys new update today I'm giving you a sneak peak at what's to come next.
Just a bit more of a peak:
Stay tuned!
Old 05-26-2013, 03:45 PM
Keilani's Avatar
PROJECTORS.
Old 06-06-2015, 02:05 PM
Kidhuf's Avatar
Update June 6th 2015
It has been awhile since I updated this thread, to say the least I've been busy, but looking forward to putting up some updates since I started this build. I got into an accident in 2014 and pulled my front end back, but it still needs some work to be straight again.
Here is a picture of the projectors in with some amber corners I had:
I sourced out a OEM black ej1 carpet and took out my old grey carpet that came with the car.
Vacuumed it at the coin op
Power washed it at the coin op
Then let it air dry in my backyard for a week.
And finally in
more updates to come when I dig up the pictures.
Old 06-06-2015, 02:13 PM
Ef9vsDa9's Avatar
keep up the good work
Old 06-07-2015, 02:34 PM
Kidhuf's Avatar
Thanks, will try to keep this updated.
Old 06-07-2015, 03:42 PM
Swaggylicious
$amGD3's Avatar
Like everything but the eBay lip, please burn and acquire oem ex lip
Old 06-07-2015, 04:59 PM
knuttveiten's Avatar
man i wish i was close to et that gray caret off ya lol. Great work on the car so far!
Old 06-08-2015, 04:39 AM
Kidhuf's Avatar
I had an oem live but sold, and got this replica spoon lip. I'm using all oem hardware but fitment is a bit off as it sags. I really would like a js racing lip or even a 5zigen lip.
Oh, sorry pal. I don't think you'd want that carpet as it was torn and also had some stains from the last owner. There are a considerable amount of grey carpets around compared to black in Canada. If I come across one I can send you the link.
Throwback to April 23rd 2013 when I got my vx rims installed.
Old 06-08-2015, 07:26 AM
Thanks man! Seems like around here they have more black interiors than gray. I have some black aftermarket carpet in mine but it fits like sht...
Old 06-08-2015, 11:03 AM
JoshTheJerk's Avatar
Nice and clean!
Old 06-09-2015, 04:57 PM
ChadB's Avatar
Clean set up.
Old 06-09-2015, 05:09 PM
joey1320's Avatar
Nice work on the door locks, looks OEM.
In for updates :-)
Old 06-10-2015, 05:25 PM
Kidhuf's Avatar
I was going to go aftermarket. But, I lost hope after seeing my brothers ek and the quality of it. So I just kept searching for over a year and finally ended up with something good.
Originally Posted by JoshTheJerk
Nice and clean!
Thanks for the nice words, it actually needs to have the front end re-aligned and have the quarters re-done.
Originally Posted by ChadB
Clean set up.
Thanks for your kind words and I appreciate you for looking at my build.
In for updates :-)
Thanks for the critism man, I used a mazda protoege power lock switch if you were wondering. You can easily find them in junk yards.
June 10th 2015 Updates
Some bad news as I was driving home from work my radiator decided to blow up on me, luckily I made it to the end of my street before shutting it off. it wasn't overheating or anything just had radiator fluid everywhere.
I ended up getting an OE replacement and fresh Honda spec 2 radiator fluid to do a full flush of the block and new radiator.
An finally after a week of waiting my Yonaka Coilovers came in from the mailman I will be installing them Friday hopefully if the weather stay warm.
The spring rates are 12k in the front and 8k in the back, they have a 0-4" drop. I don't have dampening, but heard good things about them from friends and people on d-series forums. I will definitely let you guys know how they ride and I'll make a video. I don't want to slam the car as its my daily. Im thinking 2 inch tops.
Lastly also received my rear quarter panel replacements from fixmyrust.com will be headed to my uncles shop which a 3 hour drive from my house to get him to help me put them on and then getting the car painted and front end pulled.
Old 06-11-2015, 11:19 AM
strykr89's Avatar
Looks good! Gotta love ontario winters, my car needs both rear quarters thanks to all the salt in the GTA..
Old 06-11-2015, 07:02 PM
Kidhuf's Avatar
Yeah, tell me about our winters get worse each year. I'll have to raise her back up in October and throw some anti cease on them so they are fine after winter.
Old 06-13-2015, 11:48 AM
Kidhuf's Avatar
June 13th 2015 Update
So I attempted to put on my coil overs I got the fronts on, but unfortunately the rears weren't so cooperative. I took it to a shop and got new Skunk2 LCA.
Ordered OEM Bolts expensive
On the Lift, Bushings being burnt
Finally, on the ground how she sits for now.
Next will be adjusting the height, and alignment. Then I'll be saving up for a swaybar and some gsr blades.
Old 06-27-2015, 06:55 PM
Kidhuf's Avatar
June 27th 2015
Got around to raising the car an inch in the rear to match the fronts height. Overall, right now the Yonaka Coilovers are a very smooth ride not bumpy at all and very comfortable.
I got around to replace my old dirty and beat up aem filter.
With a new vibrant filter.
Next thing I am going to get is a subframe brace and currently sourcing a type-r sway bar. Then onto body from there on out.
dj27nitro
11-05-2017 06:42 AM
mikeycivic
Paint and Body
105
11-26-2010 02:03 PM
TraKtioN
Paint and Body
05-28-2007 10:58 PM
racer_X_123
01-16-2007 09:38 AM
Quick Reply: Kidhuf 1993 ej2 build
