Car misfiring when idle
Old 05-13-2013, 10:08 AM
Bee-Otch's Avatar
Default Car misfiring when idle
I have a 98 Civic EX with a B18C GSR swap and the car is misfiring when is idling. Also, when the engine is warmed up, at idle the rpm tends to drop to 500 or so almost seems like it would cause the car to stall, but after the drop the car would rev back up to 1000 then it drops again. There is no CEL, and I changed the Spark plugs on it a few days ago is still having the same problem. Does anyone know how I can fix this problem? Thanks
Old 05-13-2013, 02:38 PM
eaf94civic's Avatar
Default Re: Car misfiring when idle
rebuild the motor, could have low compression
Old 05-13-2013, 02:55 PM
B_Swapped93's Avatar
ya good advice....OP what is your fuel pressue at idle ? have you done an injector pulse test when at idle is you ign timing on ?
hell0curry
04-04-2012 11:20 PM
LST2
07-05-2008 09:47 AM
FloridaCivic
18
02-24-2007 12:23 PM
myhatchrips
04-13-2003 02:51 PM
Quick Reply: Car misfiring when idle
