Help identify fan on 95 Accord EX V4
Old 04-30-2013, 01:06 PM
ZillaG's Avatar
Icon2 Help identify fan on 95 Accord EX V4
On my 95 Accord EX V4, which is the "radiator" fan and which is the "condenser" fan? The driver side fan has 4 blades, and comes on as car heats up at a certain temperature. The passenger side fan has 5 blades, and does NOT come on, even when A/C switch is on; hence my A/C does not work. I know it's the fan since hot-wiring it to the battery (for testing) does not spin it. The 1A Auto YouTube video on replacing a condenser fan indicates that the fan that comes on when A/C switch is on is the "condenser" fan. However, their site calls a 4-blade fan as the condenser fan, and the 4-blade fan as "radiator" fan.
Confused now?
Old 04-30-2013, 01:18 PM
charliccs's Avatar
Default Re: Help identify fan on 95 Accord EX V4
the passenger side is the radiator fan...
the driver side is the condenser fan.
Old 04-30-2013, 02:26 PM
holmesnmanny's Avatar
That site is probably just generalizing what a car could have, not what a car does have. Just pick up a fan that actually works for your car and be done with it.
Old 05-05-2013, 12:20 AM
ZillaG's Avatar
This IS absolutely correct! I just replaced the passenger side fan and now the A/C works since that fan turns when the A/C condenser kicks in.
Correct, although IMO, misleading. Shouldn't the fan that comes on when the A/C condenser comes on be called the "A/C condenser fan?"
Old 05-05-2013, 12:38 AM
Both fans comes on when the a/c is on...provided the a/c works properly. The radiator fan does come on when the a/c fan comes on at all times when the ignition is on...when the fan switch tells it to(at a high enough coolant temperature). The only difference is when the car is off...the "radiator" fan will be the only fan to come on at that time..provided the coolant is at a high enough temperature.
automan12
06-07-2014 04:26 AM
slow sol
Mid-Atlantic (Sales)
09-18-2009 04:58 AM
jonesdesign
06-18-2009 07:18 PM
GLOCKIT
08-24-2007 06:41 PM
kyle h.
Welding / Fabrication
06-22-2005 07:18 PM
Quick Reply: Help identify fan on 95 Accord EX V4
