vtec still work with d15b7 dizzy?
Old 04-21-2013, 07:19 PM
thisxlaosxguy's Avatar
Default vtec still work with d15b7 dizzy?
sup guys. ive been reading up for the past 2 days and cant find a straight answer. im doing a d16y8 head on my 91 si (d16a6) IM reading that a lot of people are using 92-95 civic d15b7 distributor because it lines right up to the y8 head. will vtec still work even though that dizzy is from a non v motor?? ill be switching to obd1 if that helps. also what should I do about the resistor box???
also has anybody ever used a jdm d16b vtec dizzy on a y8 head?
the parts I have now are:
p28 ecu
obd0-obd1 ecu jumper harness
obd0-obd1 dizzy jumper harness
obd1 injectors
obd1 fuel pressure regulator
y8 head gasket
y8 timing belt
head studs
thanks everybody for input.
Old 04-23-2013, 01:55 PM
jlicrx's Avatar
Default Re: vtec still work with d15b7 dizzy?
your B7 distributor will work just fine on the Y8 head - the distributor doesn't care if it is VTEC or not - on the Z6 head, you have to use the VTEC distributor, only because it is the only one that will bolt on, not because it is VTEC
Old 04-23-2013, 02:13 PM
Keyboard Humorist
4drEF's Avatar
Bad info.
The CYP "snail" is flipped 180 between the nonvtec and vtec distributors.
It does matter if you use a vtec or non-vtec distributor.
Code 9.
Old 04-23-2013, 02:41 PM
PHANTOM MENACE
24TEN's Avatar
^Was going to say I've read that info as well and saw the pictures of the internals.
Old 04-23-2013, 05:49 PM
Ahh crap... I just ordered a d15b7 distributor too.... I read something about flippin that "snail" anybody ever done that? I've never really looked Inside of a distributor before. I've taken the coil packs out of them but that's all :-/
EFing_Slow
01-02-2017 11:41 AM
jg31990
09-06-2012 02:56 AM
pigvwj
28
08-17-2012 08:51 PM
IDriveHonda
12-23-2003 09:30 PM
y49crxsi
12-07-2003 05:06 PM
Quick Reply: vtec still work with d15b7 dizzy?
