Transmission will NOT upshift when hit redline
Old 04-21-2013, 04:24 PM
professorman's Avatar
Default Transmission will NOT upshift when hit redline
I have a 99 Accord LX 2.3L with Automatic transmission with 120k miles. I just picked it up for my wife and I am going through the maintenance items. I changed the transmission fluid today.
I was doing a test drive today, and so I floored it, it accelerated to the red line, and I felt like I hit the rev limiter, and it wasn't upshifting, so I eased up off the pedal. I tried it a second time, I hit the redline, and sure enough, it was not upshifting. It just stayed there, bouncing off the redline fuel cutoff. After that, my Check engine light started flashing. I drove to the nearest auto store to check the CEL, but they say I have to come back in the morning . When I turn the car back on, the CEL is now constantly on.
The car drives and shifts perfectly normal otherwise. It downshifts when I push the pedal to pick up speed, and it upshifts like normal at other times.
Is it normal to not upshift when I hit the rev limited in these cars?
What could my problem be?
Old 04-21-2013, 04:42 PM
RTFM
v4lu3s's Avatar
Default Re: Transmission will NOT upshift when hit redline
check the codes and see, pretty sure it is pin 4 and pin 9 on the obd2 plug that you jumper and can count blinks.
Old 04-21-2013, 04:46 PM
Really? Didn't know that you can count blinks on OBD2. I really need to get a shop repair manual for this gen Accord.
Old 04-22-2013, 06:18 PM
The CEL says "Misfire in Cylinder 1". Could it be that the misfire occurs as the car approaches the redline, and it is a misfire that I feel rather than a fuel cut-off?
I changed the spark plugs which were well aged (very well though), but I did not change the wires nor the distributor cap & rotor.
Old 04-22-2013, 07:15 PM
MM Gruppe B
MAD_MIKE's Avatar
I do not see that as causing a no upshift, however since I have no idea what the logic is on that system I cannot say definitely that is the issue.
Back probe the TPS and see what the voltage readout is. Have you tried 3/4 throttle?
Old 04-23-2013, 02:53 AM
Yes, it upshift and downshift fine at all other throttle positions.
I disconnected the spark plug wires and hung them with a stretched bungie cord in order to do a compression test on the engine, hanging them (stretched unfortunately) so that they wouldn't spark with metal in the engine bay. I am wondering if one of the wires got a little loose on the distributor cap side.
shaquillecorvo
02-26-2016 05:47 AM
oscarlx
07-21-2012 12:41 PM
TimF16
Transmission & Drivetrain
03-28-2009 08:16 PM
o5hitbryan
12-16-2008 11:39 PM
SpoonTypeR95
08-30-2005 03:56 PM
Quick Reply: Transmission will NOT upshift when hit redline
