MPG with Cold Air Intake
Location: Pensacola, FL and every Court House in Louisiana
Re: MPG with Cold Air Intake
You might improve 1/2 MPG if you stay out of the throttle. The best thing I have noticed from aftermarket intakes are a improved throttle response.
SRI if your in a rainy place and its your DD. If you go with a CAI get a bypass to prevent hydrolock in case you ever soak the filter. I have ran my CAI without the bypass but my hatch is not a DD and saw very little rain. I removed the CAI to help get rid of the rasp it was causing in my exhaust.
just get a short ram intake if you really wanna go that route and make it sound like theres something in there. haha. with the cold air intake, you're just gonna suck up water on a rainy day. then it'll just end up ruining your day. and your car.
You will mainly gain noise, and whatever little toqrque you have to begin with will move the rev range. The transmission was down shifting more often than with OEM air box.
I only ask because I've heard if installed correctly, you can gain some mpg. While my car is a slug and probably always will be, I am not too interested in power. MPG, Stopping, Music, Turning and Appearance (slightly) is all I really care about.
Based on your input, I'd say "Skip it."
if you're looking to gain MPG's, look more to lightening your car... i think you might also look at what kind of tires you have, as well and how much air pressure you have in them.. i believe there are quite a few threads that discuss MPG gain.
longest project ever
In order to really get the full benefit of a cai u need to upgrade the ecu that way it adjust the air fuel ratio properly. Otherwise all your gonna do is gain maybe 1 or 2 hp
slide inside
06-30-2010 07:38 AM
Dc5_Dapper
26
05-14-2008 07:43 PM
