[How To] Replace the Timing Chain, Guides and Tensioner on an EP3 Type R
Old 03-27-2013, 11:23 AM
zeroprobe's Avatar
Default [How To] Replace the Timing Chain, Guides and Tensioner on an EP3 Civic Type R
I recently received the engine error code P0341 - Camshaft Position Sensor , this was found to be due to a stretched Timing Chain.
I decided to film my dad replacing it, Any comments and feedback welcome. Also look out for the additional PDF instructions in the video description.
Old 03-27-2013, 08:36 PM
mizle's Avatar
Default Re: [How To] Replace the Timing Chain, Guides and Tensioner on an EP3 Type R
nice! looks like a tight fit but manageable.
Old 05-02-2013, 01:56 PM
V4VTEC's Avatar
bump:: Have the same issue, took it to a shop and they said it's the timing. Def going to watch this vid. Thanks
Old 05-03-2013, 06:07 AM
DC5/EP3 MOD :)
Type-Spaz's Avatar
yeah changing that in the car sucks. I literally pulled the engine to do it once... was much easier lol But mad props to your dad!
Old 05-03-2013, 10:06 AM
juanvalep3's Avatar
deff needed, thanks
Posted from Honda-tech.com App for Android
Old 10-12-2013, 04:07 AM
YamahaR1's Avatar
I really have to thank you. I've been dealing with this error code for some time, and Honda quoted $1500 to replace my chain setup. This video finally gave me the moxy to take a weekend and do it myself.
I have a couple questions too.
When setting the chain, he slowly turns the right side cog with a wrench. Is this to tension the chain on the exhaust side, or merely to adjust the cams positioning?
Should you oil the chain and parts before reassembling the cover, so that when you first start it you don't do any damage to the dry chain?
And lastly, did you check the timing sensors first before assuming its the chain?
Thanks in advance, any advice welcome!
Old 10-13-2013, 11:55 PM
zeroprobe's Avatar
Hi,
Some good questions that I've probably missed in the video. Will have to put some additional captions on it to clear up.
He used the cam on the right to get the chain over to the correct position on the bottom crankshaft cog. Basically making sure all the magnetic links on the chain hit the correct points on the cogs.
We didn't oil the chain but I can't see any harm in doing so afterwards.
I remember we rotated the crank very slowly before hand and the chain was jumping as it was so slack.
vdanna
Honda Fit
10-21-2017 04:36 PM
trav_89_crx_b7
09-26-2011 02:54 PM
el_toro_de_magnifico
08-26-2008 06:21 AM
.BigSexy
10-19-2006 05:07 PM
SPORT INJECTION
22
05-30-2006 04:15 PM
Quick Reply: [How To] Replace the Timing Chain, Guides and Tensioner on an EP3 Type R
