Car jerking
Car jerking
What's up everyone. I have been recently experiencing a strange problem with my car. I will be listening to music with my phone plugged into the aux port and sometime while I'm in gear, (1st/3rd) the car will stop or kinda jerk and the music will shut off momentarily and then the car will drive normally and the music will continue. I would also like to add the fact that one time I was going about 60mph and I had to stop quickly so I pushed hard on the brake and I slowed down very quickly and the car shut off and the lights all lit up like it does before you start the car. Any ideas? thanks in advance
Re: Car jerking
Well, depending on the car (please list make, model, year), you could be having vacuum/fuel issues (stomping on the brakes draws vacuum from the motor and could stall it if your fuel/air system is pretty dirty or your idle is adjusted too low).
You could also be having ignition issues with your sound system drawing too much power and your alternator (likely getting up there in age if it's the original) may not be up to handling the increased load, putting a higher strain on your battery, and killing your ignition.
Could also be a bad ignition coil causing you to stall out as well (or you could just be really overdue for a tune-up).
Could also have something to do with your trans putting too much load/drag on the engine, but I don't know enough about manual trannies to make that sorta call.
Some things to do, in order of general cost:
Check:
Idle Air Speed
Test:
Battery
Ignition coil
Alternator
Clean:
Fuel system/intake (with Seafoam or the like)
Replace:
Fuel Filter
Spark Plugs/Wires, distributor cap and rotor, ignition coil (if all the above don't make a difference)
O2 sensors (though these will usually throw a code if they go bad...may just need to be cleaned off)
If all else fails, the problem might lie in a bad electrical ground or in the transmission...or possibly the timing of the engine itself.
Good luck!
Check:
Idle Air Speed
Test:
Battery
Ignition coil
Alternator
Clean:
Replace:
Fuel Filter
Good luck!
Re: Car jerking
Check:
Idle Air Speed
Test:
Battery
Ignition coil
Alternator
Clean:
Replace:
Fuel Filter
Good luck!
Check:
Idle Air Speed
Test:
Battery
Ignition coil
Alternator
Clean:
Replace:
Fuel Filter
Good luck!
Re: Car jerking
Alternator should put out about 12.5-12.7ish @ idle. Approx 1200-1500rpm should put out 13.2-13.4ish. Volts w/multimeter. Any lower will cause ign issues @ idle. IF your system IS pulling too hard think about bigger amp alternator or secondary battery.
Re: Car jerking
Ok, I don't have any amps or subs hookup up to the car though so I don't know why the stereo would draw power from the cars normal function.
Kels_IA
04-04-2014 12:15 PM
Dohc 4door Rye
04-06-2006 12:48 PM
Razor
04-29-2002 12:21 AM
