car wont pass smog 96 ek
Old 03-18-2013, 09:58 AM
jdmpeteek9's Avatar
Default car wont pass smog 96 ek
I have a hatch i recently purchased but it will not pass smog. The computer is not ready and it will not read the oxygen sensors were is the problem. The cat and 02 sensors i used pass smog on a different car.
Old 03-18-2013, 06:27 PM
jdmpeteek9's Avatar
Default Re: car wont pass smog 96 ek
Bump
Old 03-18-2013, 06:37 PM
B_Swapped93's Avatar
Try a diffenert ECU ? or "pay off" a garage to pass you. it's illegal but still if you can't get it working it's always an option
Old 03-18-2013, 09:17 PM
that_boy_sammy's Avatar
Im actually emissions certified now so hopefully I can help you out. Did you drive your car around for about 20 minutes before the e-test? sometimes the ecu will be in a not ready status if it hasn't been drivin long enough. On the test are any trouble codes listed? if so fix those. And if someone asked me to pass there car for 500 bucks I still wouldn't do it, there is a webcam built into the monitor Eff that.
Old 03-18-2013, 11:01 PM
hwyix's Avatar
What is the FULL history of this car and the parts you are using????? I spending days trying to help honda-tech people for them only to say a few days latter ( oh forget to mention I just changed the computer, car was in an accident, rats ate through the under hood wiring. )
I used to be a CA smog tech. Most cars take several days to go through all there drive cycles. It is not about distance. One long 500 mile drive will not to do it. Three back to back 20 minute drive will not do it. For it to count as a different drive cycle the computer wants see temps bellow 122 ish. Each manufacture probably has a different number.
This is GM's drive cycle. If you follow it there is 95% chance your car will go through all it drive cycles.
http://www.obdii.com/drivecycle.html
General Motors Driving Cycle
A complete driving cycle should perform diagnostics on all systems. A complete driving cycle can be done in under fifteen minutes.
To perform an OBDII Driving cycle do the following:
Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
Old 03-19-2013, 03:18 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Information about the car please? State you are in? ECU? Motor? Have you done the drive cycle?
Old 03-19-2013, 03:24 AM
Fnix's Avatar
What if I put 500 bucks on my gauge cluster or near OBD port where no one could see.
Old 03-19-2013, 08:11 AM
^lol that's nuts to ask 500.00 i ended up paying 100(test costs 49.99 here) to get off.
Old 03-26-2013, 01:15 PM
jdmpeteek9's Avatar
Problem solved i needed new o2 sensors and i didnt reset the battery. So i replaced my o2's and reset the ecu passed smog like a champ. When ever u have a cel light and replacing sensors please always reset your ecu.
Old 03-26-2013, 01:18 PM
jdmpeteek9's Avatar
And THANK YOU GUYS for all the imputs. Ready to swap a ls in my ek now and after that state ref
Old 03-26-2013, 07:20 PM
Thats how much my lug nuts cost dude.
Old 03-26-2013, 11:41 PM
xile6's Avatar
People don't do the illegal passing any more. They cracked down in them and they get jail time and a fine.
Also to the op. next time if you have a cel fix that first.
Old 03-27-2013, 02:42 PM
jdmpeteek9's Avatar
Yea the cel was the o2's i wasnt sure if the harness was f up so i just smog thst way then i changed them out. The car was recently purchased so i wasnt sure wat problems it had. And the idiots that worked on the vehicle removed the cel light bulb so i didn't find out till i smoged it. And yes there are shops that still illegal smog its just so much now you rather invest in your car than the smog shop.
luv.my.4dr
08-06-2009 04:30 PM
PePpeRedDc5
05-04-2005 08:01 PM
ek2k
10-15-2004 02:22 PM
out_of_order
10
10-09-2004 08:50 PM
B00ST2nR
05-20-2002 12:26 PM
Quick Reply: car wont pass smog 96 ek
