d15b2 to jdm d15b?
Old 03-17-2013, 06:05 PM
laumen1991's Avatar
Default d15b2 to jdm d15b?
i just ordered a jdm d15b for my hatch, the engine comes complete with everything including the distributor. i have a pm6 ecu which i am gonna use for the multipoint conversion. after all is said and done ill have basically no money left for a week. so im wondering is there anything else im gonna ned besides wires and connectors for the extra injectors? the dizzy that comes with the engine will work with the pm6 ecu? any info is appreciated! thanks :D
Old 03-17-2013, 10:57 PM
Red-Rocket's Avatar
Default Re: d15b2 to jdm d15b?
The dizzy has to match obd with the ecu, pm6=obd0 d15b dizzy =obd1.
It won't run at all, grab an obd0-obd1 jumper harness for the ecu side and dizzy side and swap in the d15b and convert to multi point in one swoop, you'll also need at the least a p28 ecu
Old 03-19-2013, 12:34 PM
laumen1991's Avatar
actually im going zc instead just picked it up. the import guy said i can use my pm6 ecu switch to multipoint and use the dizzy thats on my hatch right now. cause its all obdo
Old 03-19-2013, 02:49 PM
EFB055
~sp33~'s Avatar
Some jdm d15b's were obd0, you're better off going with the zc though. Much easier swap.
FLAASH
Engine Management and Tuning
05-02-2012 11:49 AM
tevezjdm3012
07-10-2011 04:59 AM
EF4lyfe
16
06-15-2004 04:21 AM
EF4lyfe
06-09-2004 05:56 PM
hondahybrids
10-13-2003 10:06 AM
Quick Reply: d15b2 to jdm d15b?
