2013 OGS SFWD Class Rules
Old 03-04-2013, 09:10 PM
rayray24's Avatar
Default 2013 OGS SFWD Class Rules
by Ortega Global Solutions (OGS)
SFWD Rules
Minimum Weights (only at Triple Crown series events, all other rules are always in effect)
67mm and smaller-2200 lbs
Up to 72 mm-2400 lbs
Non billet wheel deduct 100 lbs
*67mm and smaller turbos with larger than 83mm turbine wheel will be subject to 72 mm weight minimums.
150lb penalty for Nitrous
50lb penalty for Ethanol Based Fuel
CLASS REQUIREMENTS
ENGINE:
Engine swaps (e.g., B Series with B Series) permitted; however,
OEM engine mounting points must be utilized. Engine swap (e.g.,
B Series to a K Series) permitted provided engine swap kits are
commercially available and approved by OGS in advance. Engine
must be from same manufacturer as body. Engine must be
overhead-cam, production-based design. Maximum two power
adders. Redundant power adders, such as a dual stage nitrous
system, will be counted as one power adder. Engine must be in
stock, transverse configuration. Dry sump oil system or external oil
pumps prohibited unless OEM equipped and engine is using
complete OEM oiling system.
ENGINE CONTAINMENT DEVICE:
Engine diaper or catch-pan device to capture oil and debris in
event of engine failure mandatory. Where exhaust header passes
directly under oil pan, two-piece diaper may be utilized. FWD
vehicles using OEM manual-transmission case must also have
such a device for the transmission, to capture oil and debris in
event of transmission failure. If catch-pan device is used, catch pan
must employ minimum 2-inch-high lips on all sides. Lips must be
coved or curved inward, so as to contain oil in pan. Catch pan
must cover entire area below engine/transmission. Catch pan must
extend from radiator support to firewall and from framerail to
framerail. In all cases, lips must be adequate enough to contain oil
in the catch pan. Should a competitor spill excessive oil from the
catch pan and debris onto the track, he or she may be disqualified
from further competition at the sole and absolute discretion of the
event director until catch pan is upgraded, regardless of height of
pan lips or pan design.
EXHAUST:
Not required.
FUEL:
NHRA-accepted racing gasoline permitted. Injection of any other
fuel prohibited (e.g., methanol injection). See General Regulations 1:6.
E85 is permitted with no alterations from the manufacturers. Any modifications to the ethanol from the manufacturer specs (eg. origin, oxygenation, gravity) will be disqualified from the event. Competitor must declare which fuel will be used during the event and must not deviate from it.
FUEL SYSTEM:
Fuel cell OK. NHRA guidelines MUST be followed. No other container,
fuel cell, bottle, etc. may contain any type of fuel. All cars must be
equipped with a drain valve located on return side of fuel rail to
facilitate removal of fuel samples for fuel-check purposes. See NHRA
General Regulations 1:5.
LIQUID OVERFLOW:
See NHRA General Regulations 1:7.
NITROUS OXIDE:
Commercially available nitrous oxide permitted, including for
supercharged and turbocharged engines. Nitrous bottle(s) in driver
compartment must be equipped with a relief valve and vented
outside of driver’s compartment. Bottle(s) must be stamped with a
DOT-1800-pound rating and permanently mounted (no hose
clamps or tie wraps). Hoses from bottle(s) to solenoid must be
high-pressure steel-braided or NHRA-accepted hoses.
Commercially available, thermostatically controlled, blanket-type
warmer accepted. Any other external heating of bottle(s)
prohibited.
SUPERCHARGER, TURBOCHARGER:
Permitted. Restricted to a single turbocharger. Turbocharger must
utilize a turbine housing inlet flange commonly referred to as a
T04. The turbine housing inlet flange may be smaller but may
never exceed the T04 dimensions in any direction. Limited to a
maximum 72mm turbo, where the maximum compressor housing
inducer diameter is 72.78mm (67mm-67.9 maximum), measured at the point where the
leading edge of the compressor wheel meets the housing. Compressor wheel inducer diameter not to exceed this
value, and contours of wheel must not be “stepped, notched, or
clipped”; e.g., the contours must be continuous features from the
inducer to the wheel exducer. Exducer limited to 102mm for billet wheels, 105mm for cast wheels. 67mm and smaller turbos limited to 94mm maximum exducer. Exotic material wheels prohibited. Modified turbo housing is not allowed.
Intercooler must be air to air only. CO
2 or NOS is permitted as a
cooling medium in place of water in liquid intercooler, but will count
as a second power adder; i.e., if CO
2 or NOS is used as an
intercooler medium, NOS may NOT be used in the engine. OEM
liquid intercooler permitted only if OEM engine and OEM power
adder are used. Racing-type screw supercharger prohibited.
FLYWHEEL SHIELD:
All cars using a clutch and running quicker than 11.49 or faster
than 135 mph must be equipped with a flywheel shield made of
1/4-inch-minimum-thickness steel plate. Shield must surround the
bellhousing completely except for area of flywheel shield adjacent
to differential and axle shaft. Shield may be multi-piece with pieces
bolted together using minimum 3/8-inch-diameter Grade 5 or M10
class 8.8 bolts; may be attached to engine and/or bellhousing. In
lieu of shield, a blanket meeting SFI Spec 4.1, completely
surrounding the bellhousing, is permitted. See NHRA General Regulations
2:5, 2:6, 2:9,
TRANSMISSION, AUTOMATIC:
All cars using an automatic transmission and running quicker than
10.99 or faster than 135 mph must be equipped with a
transmission shield meeting SFI Spec 4.1, a flexplate shield
labeled as meeting SFI Spec 30.1, and a flexplate labeled as
meeting SFI Spec 29.1. Transmission must be OEM for engine
used. Non-OEM or aftermarket transmission prohibited.
Transmission brake prohibited.
TRANSMISSION, MANUAL:
Automated, timer-type, pneumatic, electric, electronic, hydraulic,
etc. shifting mechanism prohibited; each individual shift must be a
function of the driver and controlled manually. (Driver must pull the
lever.) Non-OEM or
BRAKES:
Four-wheel hydraulic brakes mandatory. Carbon fiber brake rotors
prohibited. See NHRA General Regulations 3:1.
STEERING:
Must retain full, original OEM steering gear. See NHRA General
Regulations 3:3
SUSPENSION, FRONT
Upper mounting point for strut assemblies must be in the factory
location. Adjustable caster/camber pillowball mounts are permitted.
Lower control arm may be strengthened provided factory mounting
points to chassis are maintained. Lower mounting point for strut
assembly may be modified for improved caster or camber. Strut
tower braces, lower tie bars, sway bars, and limit straps are
permitted. Traction bars/devices permitted; must be bolt on ONLY.
Final decision rests with OGS Technical staff.
SUSPENSION, REAR:
Aftermarket lower control arms, strut tower braces, lower tie bars,
sway bars, and limit straps are permitted. Rear suspension must
maintain minimum shock travel of 1 inch. All rear suspensions must
use at least one working shock absorber per wheel. Suspension
modifications limited to bolt-on items only. Only OEM suspension
mounts/attachment points may be utilized. Spindle mounts
prohibited.
WHEELIE BARS:
Prohibited.
BALLAST:
Permitted. See NHRA General Regulations 4:2.
CHASSIS:
OEM chassis, with complete OEM floorpan and firewall,mandatory. Wheel tubs, back-half conversions, tube chassis, etc.prohibited. Must retain FWD configuration; rear-drive conversionsprohibited. Engine must be located in OEM location for body used. Roll bar mandatory in any car running 11.49 or quicker; roll cage mandatory in any car running 9.99 or quicker or 135 mph or faster. Roll cage in cars running 9.99 or quicker must be inspected every three years by NHRA and have serialized sticker affixed to roll cage before participation. See NHRA General Regulations 4:10, 4:11, 10:6.
GROUND CLEARANCE:
Minimum 3 inches from front of car to 12 inches behind centerline of front axle, 2 inches for remainder of car (except for exhaust
more than 12 inches behind centerline of front axle).
PARACHUTE:
Mandatory on any car running 150 mph or faster. See NHRA General
Regulations 4:8.
WHEELBASE:
Must retain original wheelbase for body used, plus or minus 1 inch.
Maximum wheelbase variation from left to right is 1 inch.
TIRES:
DOT or racing slicks permitted with a maximum width of 9.0 inches
and maximum height of 25.0 inches. Retreads, space-saver
spares, or any other non-DOT-approved tire prohibited.
WHEELS:
Must be automotive-type wheels suitable for street or racing use.
Minimum wheel size 13 inches unless originally equipped with
studs must be threaded into hex portion of lug nut a distance at
least equal to the diameter of the stud. Maximum width size is 10 inches.
Spindle mounts prohibited.
See NHRA General Regulations 5:2
INTERIOR:
Complete interior, including dashboard, door panels, headliner, etc.
mandatory. Rear seat may be removed. Two front seats
mandatory. Aftermarket seats permitted, but must be fully
upholstered.
BODY:
Pickup and SUV bodies prohibited.
Mild customizing and body kits permitted, but must retain fullbodied
appearance, with minimum two functional doors. Chopped
roofs prohibited. Doors must open and close from
inside and outside. Windshield and all windows must retain OEM
safety glass.
Lightweight body panels limited to hood, fenders, and deck lid.
Aftermarket body kits permitted, but full street-legal appearance
must be maintained. 50% of the air to air intercooler must be exposed to keep the spirit of the class. One-piece aftermarket front end prohibited.
COMPETITION NUMBERS:
See NHRA General Regulations 7:2.
FIREWALL:
Complete OEM firewall mandatory. Mini-tubbing prohibited. See
NHRA General Regulations 6:1, 7:4
FLOOR:
OEM floorpan, front to rear, mandatory.
STREET EQUIPMENT:
Complete headlight and taillight
assemblies (all) mandatory; must be operative. One headlight may be removed for intake ducting.
WINDSHIELD/WINDOWS:
Complete OEM windshield and windows mandatory. Windows must
be operative per factory specifications. (Must open and close via
electrical or OEM mechanical means.
BATTERIES:
Batteries must be securely mounted; may not be located in driver
compartment unless sealed off per General Regulations. See NHRA General Regulations 8:1.
IGNITION:
Two steps, rev limiters, etc. permitted. See NHRA General Regulations
8:1, 8:3, 8:4, 8:5.
MASTER CUTOFF:
Mandatory on any car running 9.99 or quicker, or 135 mph or
faster, or on any car where battery is relocated to trunk area of
vehicle. See NHRA General Regulations 8:4.
COMPUTER: Prohibited. See NHRA General Regulations 9:1.
DATA RECORDER:
Permitted. See NHRA General Regulations 9:2.
FIRE EXTINGUISHER SYSTEM:
Permitted; must be securely mounted. See NHRA General Regulations
9:3.
TOW VEHICLES:
Prohibited.
WARM-UPS:
See NHRA General Regulations 9:4, 9:12.
CREDENTIALS:
All competitors must have competition number and membership
number. Valid NHRA competition license mandatory for driver of
any vehicle running 9.99 or quicker. All drivers running 10.00
seconds or slower must have a valid state- or government-issued
driver’s license beyond a learner’s-permit level or valid NHRA
competition license. See NHRA General Regulations 10:4.
DRIVER RESTRAINT SYSTEM:
Three-inch-wide driver restraint system labeled as meeting SFI
Spec 16.1 mandatory in any car required to have a roll bar or roll
cage. System includes crotch strap and must be updated at twoyear
intervals from date of manufacture. All other cars, OEM
restraint system mandatory. See General Regulations 10:5, 10:11.
HELMET:
See NHRA General Regulations 10:7.
NECK COLLAR:
Mandatory on driver of any car running 9.99 seconds or quicker or
135 mph or faster. See NHRA General Regulations 10:8.
PROTECTIVE CLOTHING:
9.99 to 7.50 or any car exceeding 135 mph:
Jacket and pants
meeting SFI Spec 3.2A/5 and gloves meeting SFI Spec 3.3/1 mandatory.
Ethanol fuel safety requirement as follows: Suit meeting SFI Specs 3.2A/15, gloves and boots meeting SFI Spec 3.3/5 mandatory.
All others, see NHRA General Regulations10:10
ANY MODIFICATION THAT DEVIATES FROM THE RULES WILL BE A VIOLATION AND WILL CAUSE IMMEDIATE DISQUALIFICATION FROM THE EVENT AND A PRESS RELEASE WILL BE CREATED WHY THE RACER IS DISQUALIFIED.
(eg. 1 piece front end, mislabeled tire size, etc…)
PLEASE DIRECT ALL TECH RELATED QUESTIONS OR ISSUES TO OGSTECH@GMAIL.COM
© Ortega Global Solutions 2013
Old 03-05-2013, 05:55 AM
Bayshore Power's Avatar
Default Re: 2013 OGS SFWD Class Rules
Really 150 pounds for nitrous after 10 years of it being legal overnight it's 150 pound weight penalty?
Old 03-05-2013, 06:05 AM
TDautowerkes's Avatar
Working headlights and tail lights have never been enforced. I agree with some of the rules but to keep the spirit of the class,%50 of intercooler must be exposed? Who determines what %50 is? We have downpipes coming out of the hood and wheels that stick out like roller skates.
Old 03-05-2013, 06:12 AM
d16z6Tcrx's Avatar
50 lb for e85? crazy?
Old 03-05-2013, 06:38 AM
fmfkid250's Avatar
Wow so there is no advantage of the $3500 6785 or the Borg Warner 67.7...wonder if Irev going to boot these turbos out of true street.
Old 03-05-2013, 06:39 AM
Abraham-ATS's Avatar
good thing im not done with both of our cars so i can adjust to the rules... they seem pretty fair as long as we enforce them for everyone!
Old 03-05-2013, 06:49 AM
01DC4's Avatar
*67mm and smaller turbos with larger than 83mm turbine wheel will be subject to 72 mm weight minimums.*
So is that 83.0 or 83.9mm?
Old 03-05-2013, 06:52 AM
Moderator
crazes's Avatar
maybe cause of FTW i think its based on..
well there is rocket e85 and pump e85 but i doubt few people are running it
Old 03-05-2013, 07:10 AM
so basically the changes were
1-50 lbs for ethanol based fuel.....
2-150 lbs for nitrous
3-%50 of intercooler must be exposed. What if you don't run an intercooler? should %50 of piping be shown?
4-headlights and tail lights must all work? or must all be in place? the track is lit well, and we rarely race at night.
5-race suit 3.2-15sfi must be used with all ethanol based cars.
6-10' wide maximum width of rim measured from where to where?
Old 03-05-2013, 07:21 AM
061000rr's Avatar
so it boils down to every car that was fast last year and set records now has to add 200+ lbs to there car so the slower guys can catch up.
Old 03-05-2013, 07:24 AM
Moderator
crazes's Avatar
yup.. guess closer racing makes for better entertainment. kind of pro mod
Old 03-05-2013, 07:34 AM
its not closer racing cause the rules apply to everyone..... The fast cars will always be the fast cars ....... the guys that are going fast are just more creative withe the rules and manage to find a way to work around them. Those rules arent gonna stop the fast guys from going fast.
what i would like to know is why limit wheel width, and why add 150 lbs for nbitrous when its been alowed since javier worked for NHRA,
Old 03-05-2013, 07:56 AM
061000rr's Avatar
so if you run sfwd but dont enter the triple crown points series you DONT have to add weight for any of the stuff listed as penaltys?
Old 03-05-2013, 09:10 AM
dturbocivic's Avatar
the car will need to fit the rules of the class in order to enter. otherwise you might as well just enter quick 32
Old 03-05-2013, 09:15 AM
PRO1's Avatar
thats why my red neck a$$ stays teh F*ck home
Old 03-05-2013, 09:44 AM
tepid1's Avatar
I like these rules. They are mostly based around SAFETY. That's what's most important.
Old 03-05-2013, 10:56 AM
tepid1's Avatar
# 4, 5, 6 are clearly for safety.
I will agree, I don't understand the whole intercooler being exposed, only using 9" wide tires, etc. I do see them trying to make the class tight and competitive, while keeping safety upmost important.
Old 03-05-2013, 11:09 AM
061000rr's Avatar
its been 1 working taillight for as long as ive been in this game. and not just import. pretty much every single league out there is only 1 tail light
Old 03-05-2013, 11:15 AM
boosted92snatch's Avatar
I can understand the suit for the ethanol fuels but no wider than a 10" rim??? And intercooler must be shown cmon now they might as well make it a true street shoot out! And thats why i dont go to the NJ events(and the BS sound curfew). Its sfwd let them have what theyve always had and have some good racing!
Old 03-05-2013, 12:37 PM
d16z6Tcrx's Avatar
this is f*cking stupid. rather than add these stupid *** rules just tell miller he"s an ******* and we dont want you at our events. it gets obscenely clear every year with these rule changes and then added tech checks to his or his customers cars that just make it painfully obvious you dont like the man. you add a 50lb weight penalty because his fuel works? 50lbs for fuel? fucck outta here
Old 03-05-2013, 12:59 PM
061000rr's Avatar
this isnt pointed at miller. alot of people are running c85 witch will also make them add 50lbs.
Old 03-05-2013, 01:16 PM
EDLOVA23's Avatar
c85 here and now im on the search for a new SFI 3.2A/15 suit
Old 03-05-2013, 01:27 PM
King of the One Liners
2fastGSR's Avatar
The headlight and taillight rules have ALWAYS been there. Whenever you race at night in the North East, the track staff will tell you to turn on your lights. I have even seen them stop people at Atco if they didnt have working taillights.
Old 03-05-2013, 01:30 PM
Moderator
crazes's Avatar
not going to lie its kind of funny.it almost looks like it but i doubt thats actually the reason behind it
Old 03-05-2013, 01:33 PM
K20Ahondas's Avatar
Yo!! Relax. 50lbs is nothing. I remember when fuel had 100lb weight penalty when it came to race gas vs any kind of alcohol.
There are other e85 fuels out there besides our FTW. FYI
Quick Reply: 2013 OGS SFWD Class Rules
