Place your bets.
Old 03-03-2013, 12:34 PM
Lo-Buck EF's Avatar
Default Place your bets.
B16a (p30) unopened from japan.
replaced: valve train, oil pump, cams, intake mani, & oil pan.
New trans was also acquired. Moved the diff and final over from the old one.
Old 03-03-2013, 12:54 PM
miamirice's Avatar
Default Re: Place your bets.
Old 03-03-2013, 03:27 PM
Ridin Dirty in Cali
dirty19's Avatar
Get some Spence!
You are due for a good run here this year!
Old 03-03-2013, 06:12 PM
1998GsRIntegra's Avatar
Going to be a problem free year. You're due for it. Those little things are about as bulletproof reliable as it gets. It's what we started with in our crx and after 18 race weekends, a mis-shift killed it. It was still going strong up until then and hadn't missed a beat.
Hopefully going to be a good year for us...I just finished our engine
Old 03-03-2013, 07:11 PM
Atmosfear's Avatar
W00t! Good luck Spence
Old 03-04-2013, 06:13 AM
Gearspeed-Performance's Avatar
1st day out it will die
Old 03-04-2013, 06:15 AM
navin's Avatar
And a new clutch/flywheel correct?
Old 03-04-2013, 08:27 AM
vtecjj's Avatar
3 race weekends..tolerances are too tight for the racing we do. imho
Old 03-05-2013, 01:02 PM
Lo-Buck EF's Avatar
new clutch. same flywheel (it was checked and is fine)
thanks gearspeed & meris!! :D
Old 05-11-2013, 03:40 PM
Lo-Buck EF's Avatar
well, no bearing material in the pan after the first round (3 days on track). but there is something metallic in there. FML
Old 05-11-2013, 04:25 PM
Robin6's Avatar
^^^mystery metal, got to love it! lol
If the engine starts to make strange noise, get a louder exhaust.
Old 05-11-2013, 04:36 PM
Lo-Buck EF's Avatar
i already got the loudest option
Old 05-11-2013, 06:25 PM
Robin6's Avatar
ah! then you will be fine!
May your engine live long and you prosper!
Old 05-14-2013, 07:22 AM
joel n's Avatar
We just installed a moroso pan so i took a good look at the pan that cam off. lol. There was a 1inch X 1/2inch x 1/4INCH rock in the oil pan. A 1inch long pin from something all beat to hell and lots of shinny metal. LOL. We lost VTEC 4 times last year and were running the car hard for a few laps when it happened the first time (didnt know why we lost VTEC so just keep running). The oil pick-up was hard into the pans once before from the marks i see in the pan. I run the motor hard, even running on the limiter in one spot of the track, and still the motor works great. I think its the motors 4th season, 2 with me and 2 before. Your luck blows we away. I hope this one continues to work good for you.
We run a old B17A1 motor.
Old 05-14-2013, 09:48 AM
Spongebrad Squarepants
Egezzy's Avatar
You should have went with a Gallo 24!!
Old 05-14-2013, 10:40 AM
rice_classic's Avatar
I bet you'll still have air in your brake lines...
Wait, am I in the wrong thread?
Old 05-15-2013, 08:34 AM
Lo-Buck EF's Avatar
HahhahhahhHhhahhaahahhaaa
Don't even start. The brakes gave me fits yet again at the first round! Dragging like crazy!
Old 05-15-2013, 09:54 AM
HT White Ops
Redcivic92's Avatar
My bet is that if you don't over rev it we are going to have some GREAT racing this weekend.
Old 11-04-2013, 10:17 AM
Lo-Buck EF's Avatar
*UPDATE*
About 1200 track miles later, not a SINGLE problem. went back to a stock pan with baffles, used rotella and changed it every weekeknd. damn thing uses maybe a quart in 3 days which im fine with and it hasn't been to the dyno. just ran on an old tune, watched the AFRs and checked the plugs. i even finished 2nd in points in HC2! Redcivic92 (erik) beat me by 5 points!! If it wasnt for a few retirements i had, i would have won it (fogging windshield and 2 high water temp issues from grass in the grill and a rad cap working itself loose).
Old 11-04-2013, 10:27 AM
Ridin Dirty in Cali
dirty19's Avatar
Woooooooo good deal Spence.
Leave it alone, and run it again next year
Old 11-04-2013, 10:50 AM
Robin6's Avatar
*UPDATE*
Rock'N!
Old 11-04-2013, 10:55 AM
Lo-Buck EF's Avatar
thats the plan. just keep changing the oil. heck, i only adjusted the valves once all season!
the winter mods/ upgrades will be small. the car works just fine and is fast enough to compete with the big C5s in the class. next year wil be about continuing the reliability and trying to make it to nationals at ROAD ATLANTA!!!!! Can't wait to race my down south brothers down there!!!
Old 11-04-2013, 11:17 AM
Ridin Dirty in Cali
dirty19's Avatar
So Nats is moving to Road Atlanta then?
Old 11-04-2013, 12:07 PM
*UPDATE*
About 1200 track miles later, not a SINGLE problem. .
Old 11-04-2013, 01:21 PM
Egezzy's Avatar
RA in the bEast and Sonoma in the West.
Quick Reply: Place your bets.
