Recaro Pole Position SPG - which rails?
Old 03-03-2013, 02:40 AM
jimlaH's Avatar
Default Recaro Pole Position SPG - which rails?
Hey guys just purchased 2x recaro pole position spg seats for my DC2R
both seats have the side mount brackets i just dont know
which rails to use with them.
will dc2r recaro sr3 rails bolt up to the side mount brackets?
or do i use something else like bride RO rails?
pics of the seats
Old 03-03-2013, 05:10 AM
Devon M's Avatar
Default Re: Recaro Pole Position SPG - which rails?
Buddy club rails work well, PCI work well but don't have sliders. You could also buy the sparco brackets and sliders to bolt to the recaro side rails. If you go that route pm me, I have a new set I'd let go for cheap.
Old 03-03-2013, 06:48 AM
B serious's Avatar
Buddy club rails are sooooo awful.
Old 03-03-2013, 11:06 AM
Devon M's Avatar
Personally I have never used them. Why do you say that? Too much movement?
Old 03-03-2013, 07:24 PM
jdmspoonitr's Avatar
You can use Mugen, Bride, etc.
Old 03-03-2013, 08:17 PM
jimlaH's Avatar
which bride rails? bride type ro?
Old 03-03-2013, 08:27 PM
B serious's Avatar
The welds commonly break (atleast on S2000 rails). Ironically, I had read about people breaking their welds, and I removed my seats to check. The rear attachment point weld was busted. I'm not a big guy...5'11, 165-170LBS. It's not like I weigh 300lbs and jump into my seat from the 2nd floor.
I had both rails re-welded solid. The problem is that buddy club only spot welds on one point to join the attachment points. The sliders are constantly coming loose, so the seat jiggles, and inspite of that.... the sliders have way too much resistance when you try to move them.
Old 03-04-2013, 02:02 AM
Devon M's Avatar
Good to know for future reference.
Old 03-04-2013, 08:44 AM
3rdtimecharmer's Avatar
call up wedge engineering
Old 03-05-2013, 10:01 AM
Bride has two types of rails. Ones meant for bottom mount seats and ones meant for side mount seats. SPG's are side mount. You might need to modify those Recaro side plates to mount on Bride rails. By modify I mean use a dremel and cut out a small section.
You can also use the supplied side brackets that come with the Bride rails, which essentially look like little L brackets with holes drilled in them.
Old 03-27-2013, 02:01 AM
jimlaH's Avatar
just tried my friends PCI rails, the seats sit off centre about an inch towards the door, will try flipping the brackets around to hopefully gain more clearance so i can slide the seat in towards the middle of the car.
does any1 know if buddyclub rails sit the seat perfectly centered in a dc2?
Old 03-27-2013, 05:20 AM
itrSteez's Avatar
PCI's rule, I loved mine.
ps: my passenger one is for sale
Old 03-27-2013, 06:15 AM
teg97's Avatar
great seller btw! buy with confidence!
Old 03-28-2013, 03:30 PM
coolhandluke's Avatar
Originally Posted by jdmspoonitr
You can use Mugen...
Mugen won't work with the wider Recaro seats.
I have owned two sets of Buddy Club rails, no issues.
Old 03-28-2013, 03:56 PM
jimlaH's Avatar
Cheers Luke! Seems like buddy club rails are the way to go
Old 03-28-2013, 07:57 PM
yztzzxga's Avatar
Old 03-28-2013, 09:19 PM
Finland's Avatar
when I had aftermarket Recaro seats in my car, I used Sparco 400SB018R/L part number mounts with standard universal Recaro sliders. Easypeasy.
big.turbo.daddy
05-19-2014 12:13 AM
Twenty47
07-21-2008 01:06 PM
MugenGTR
09-23-2006 11:18 PM
92jdmhatch
Honda S2000
11
01-01-2005 10:12 AM
RTW DC2R
12-05-2002 01:52 PM
Quick Reply: Recaro Pole Position SPG - which rails?
