I am still stumped, injectors won't fire.
Old 03-01-2013, 11:01 AM
crxmadness's Avatar
Default I am still stumped, injectors won't fire.
I started a couple of other threads a couple of months ago, but nothing has worked.
Info:
89 crx
b16
obd0
My injectors are not firing. I have checked continuity. I have 2 ecu's (pr3 and pwo) and get the same results with both. I replaced my crank angle sensor pins and she fired up, but only ran for 10 minutes and shut off. Hasn't started since. I am getting zero codes.
I am stumped, I really don't want to start throwing parts at it, but I really am at a loss. I need a list of reasons of what would cause the pulse to not be sent to the injectors.
In the other thread someone mention it could be a bad ground, where would I find the ground that controls the injector pulse?
Old 03-01-2013, 08:30 PM
go-part's Avatar
Default Re: I am still stumped, injectors won't fire.
http://www.wikihow.com/Test-Fuel-Injectors
Old 03-01-2013, 09:22 PM
crxmadness's Avatar
Originally Posted by go-part
There is nothing wrong with my injectors, I have already tested them. My problem is that my injectors are not being sent the pulse to fire.
Old 03-01-2013, 09:52 PM
grog's Avatar
So was it running fine before? Or did you just do the swap?
Any CEL codes coming up?
Do you have obd0 injectors or obd1? Are you using the resisitor box?
The ground to check is on the thermostat housing.
Old 03-02-2013, 04:44 PM
swordofdoom's Avatar
have you done the MPFI swap?
Old 03-03-2013, 05:20 PM
crxmadness's Avatar
It was running fine before, one day it just shut off. Did some tests and found out the injectors were not firing.
no cels
obd0 and yes running resistorbox
scuffed up the ground on the thermostat and bolted it back down
Old 03-03-2013, 05:22 PM
crxmadness's Avatar
I have an 89 HF so it came MPFI from the factory
Old 03-05-2013, 06:46 AM
crxmadness's Avatar
ttt, ideas anyone?
Old 03-05-2013, 07:11 AM
PHANTOM MENACE
24TEN's Avatar
I recently just experienced the same issue. I got to the point where I was ready to rip out the wiring harness and start manually tracing where the power/continuity stops between the main relay and injectors. I got it running a couple of days ago, problem was my distributor. More specifically the sensors integrated into the distributor (cam and crank position sensor I believe). The coil and ignitor were both replaced with new not used units and it still wouldn't start so I figured the issue was else where until my buddy loaned me an extra distributor.
My thread is a couple pages back now if you wanna read and see the trouble shooting process.
Old 03-05-2013, 05:15 PM
crxmadness's Avatar
posting up for reference:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/1991-honda-civic-no-start-condition-3101841/
Old 06-11-2014, 01:10 PM
crxmadness's Avatar
U da man 24TEN I bought a brand new td22u distributor andi havent had a problem since!
Old 06-11-2014, 02:29 PM
PHANTOM MENACE
24TEN's Avatar
OMG it's been over a year!! Glad you got it running though
JDMCIVIC919
12-08-2011 07:47 AM
KrispyKreme
01-04-2006 08:39 PM
caspers_hatch
02-27-2005 11:47 PM
TurboJesse
06-29-2003 04:31 PM
tinkerbell
08-18-2002 03:34 PM
Quick Reply: I am still stumped, injectors won't fire.
