tandem valve control
Old 02-26-2013, 08:36 PM
Ken Knowles's Avatar
Default tandem valve control
What does this do? Is it a choke?
Old 02-27-2013, 06:51 AM
Keyboard Humorist
4drEF's Avatar
Default Re: tandem valve control
It is sort of like a choke, but designed more with fuel efficiency in mind.
There are 2 sets of butterflies in the DPFI throttle body.
The lower one is your throttle plate for acceleration.
The upper one is for the tandem function. It isn't a full butterfly as it has a cut out to allow air through. It redirects air around the injector for a better mixture rather than restricting air like a choke does.
Old 02-27-2013, 07:52 PM
I'm missing the 12v on the black and yellow wire. If this wasn't working correctly, could it effect my O2 sensor?
Old 02-28-2013, 06:07 AM
Keyboard Humorist
4drEF's Avatar
Probably at high RPM.
Drivability will also take a hit as you will be losing power.
Old 03-01-2013, 03:50 AM
It caused my car to surge when I tried to accerate. I zipped tied it open until I can get to the troubleshooting this weekend. Will his cause any problems?
Old 03-01-2013, 05:55 AM
Keyboard Humorist
4drEF's Avatar
It shouldn't cause any big problems.
I have read that it reduces power at low RPM to drive with it open.
Joe Techy
Honda CR-V & Element
02-16-2019 07:35 AM
kailapics
Honda Civic (2001 - 2005)
12
02-04-2013 01:46 AM
rockwilda
02-23-2002 09:43 AM
Quick Reply: tandem valve control
