92 Accord Dome Light/Rear Defroster/Cigarette Lighter Issue
Old 01-29-2013, 10:19 AM
Mykul's Avatar
Icon2 92 Accord Dome Light/Rear Defroster/Cigarette Lighter Issue
I have a 1992 Accord LX. My car currently has no power to the dome light, cigarette lighter, rear defroster and the power antenna does not work. I do have power to the radio. The power to these item died when I took the power adapter for my GPS out the cigarette lighter.
I did not find any blown fuses under the driver side dash panel.
Under the hood I did find a blown fuse to the #22 slot and the #29 slot. After replacing those two fuses there is still no power to the items that were failing previously. I also checked the back of the cigarette lighter to see if the solder melted from the the connecter inside the white plastic fuse but it wasn't melted. I am still having the same issue.
What should I test or look at now?
Old 01-29-2013, 10:47 AM
gdrew888's Avatar
Default Re: 92 Accord Dome Light/Rear Defroster/Cigarette Lighter Issue
There is a fuse panel under the hood, passenger side near firewall. I'm not sure and not near the car so can't confirm but I think there is a fuse or relay for rear defrost etc in that box.
Old 01-29-2013, 12:55 PM
Mykul's Avatar
Icon2 Re: 92 Accord Dome Light/Rear Defroster/Cigarette Lighter Issue
I forgot to say that I did find a blown fuse to the ECU in the fuse box under the hood. I replaced it and still the same issue.
Old 02-07-2013, 10:59 AM
Mykul's Avatar
I went through all of the fuses under the hood and the drivers side panel with a test light in KOEO and all the fuses tested ok.
What should I look at now?
Old 02-09-2013, 05:44 AM
poorman212's Avatar
Start with the rear defrost. Pull the switch and see if you have power to the YEL/BLK wire with the key on?
When you had the socket out, did you test for voltage?
Stock or aftermarket radio?
Old 03-11-2013, 04:46 AM
Mykul's Avatar
No power to the defrost switch. The radio is after market and works fine. There is no power to the dome light or the cigarette light either. I suspect it is the ECU unit under the dash.
Old 03-11-2013, 04:49 AM
92 civic ex 4dr's Avatar
The ecu has nothing to do with power given to your Accessories. How is the radio hooked up? Red and yellow wires hooked up to the vehicle harness? Or are they heading out in they're own direction?
Posted from Honda-tech.com App for Android
Old 12-04-2013, 06:56 AM
Mykul's Avatar
The radio harness is from Crutchfield. It connects to the Honda radio harness through a stock connection.
The radio works fine.
aleks77
01-29-2023 11:39 AM
beeman 001
Honda Civic (2001 - 2005)
09-25-2017 09:40 AM
mtnblue
03-29-2016 02:05 PM
Sepulveda87
05-01-2015 04:53 AM
Quick Reply: 92 Accord Dome Light/Rear Defroster/Cigarette Lighter Issue
