Genuine Honda ATF
Old 01-19-2013, 03:24 PM
luvmycrv's Avatar
Default Genuine Honda ATF
I have an 09 crv and have been bringing to the dealer for maintenance due to the 3 year warantee. Warantee is over and time for my 2nd tranny fluid change I have a little over 30,000miles on it. Can I use any ATF fluid or does it have to be Honda ATF it says in my manual to use genuine honda ATF??
Old 01-19-2013, 07:07 PM
sliverSE.V's Avatar
Default Re: Genuine Honda ATF
you can use any ATF for Honda/Acura from your auto parts store if you like...me I'm sticking with the OEM Honda ATF
...if your don't care and not going to keep the car/suv long put whatever you want in it..if you want to keep it forever, take care of it right with OEM
GL
Old 01-19-2013, 09:54 PM
NZ-DB8R's Avatar
Use OEM, you will only cause issues and possibly damage by using other fluids. Up to you though
Old 01-20-2013, 12:45 AM
KWayRacing's Avatar
Oem is best for your vehicle. It was specifically designed to be used in your transmission whereas other atfs were not.
Old 01-20-2013, 07:34 AM
ian1006's Avatar
OEM all day every day
s15jake
Transmission & Drivetrain
11-07-2011 07:48 AM
jjager13
06-05-2011 06:52 AM
SpazMan
02-18-2009 10:49 PM
return_2020
07-20-2004 08:43 PM
jk
09-24-2002 02:11 PM
Quick Reply: Genuine Honda ATF
