passanger headlight not having full power? very dim.
Old 01-19-2013, 12:28 PM
pliskin679's Avatar
Default passanger headlight not having full power? very dim.
My 98 accord passanger side headlight is really dim. so i bought new headlights, still Dim. my friend reccomended replacing the connector where you put the bulb in cause the connections can go bad. I went and got HID kit, choped the old connector to make room for the new one. Now the light just flickers, then when its solid, its still really dim. So im assuming the connection is bad elsewhere... Any idea's?
Old 01-19-2013, 01:06 PM
redyute's Avatar
Default Re: passanger headlight not having full power? very dim.
Check for poor ground connection
Old 01-19-2013, 01:28 PM
jdowen2's Avatar
Doubt if this is the problem but swap headlight relays
Old 01-20-2013, 11:21 AM
pliskin679's Avatar
Headlight relay is fine, any idea where the ground for this is? Could I just gangster rig it and put the black cable to the frame somewhere?
Old 01-20-2013, 01:35 PM
jdowen2's Avatar
There are 2 headlight relays. Ground is located right (pass.) side of engine compartment, stack of 5 ground wires.
Old 01-21-2013, 03:47 AM
jabontke's Avatar
I second the ground. That is the first thing that came to my mind. Be sure your ground wire has a clean, non-painted contact with the frame.
Old 01-27-2013, 09:17 AM
pliskin679's Avatar
i ran the ground directly to the battery and the headlight is still the same brightness, now using 2 different headlights to make sure its not just a dud light. Where is the relay? i want to make sure i checked the right thing?
Old 01-27-2013, 09:52 AM
jdowen2's Avatar
Relays are in underhood fusebox.
Old 01-27-2013, 03:40 PM
pliskin679's Avatar
was a fuse, thanks all
bigballer8526
05-09-2017 05:59 PM
crx_underground
08-10-2010 09:51 AM
sik_sol
04-14-2005 01:51 PM
WANARUNM
11-30-2004 06:39 PM
Q-OnE
08-14-2002 05:49 PM
Quick Reply: passanger headlight not having full power? very dim.
