help: front motor mount engine bracket
I have snapped both of my studs in my motor mount bracket -the one attatched to the engine itself. I've tried tapping thru the old stund but i was unsuccessful. I purchased a new bracket. I am runing into a slight problem. Ive taken my valvecover in order to remove the upper timing belt cover, now i am trouble removing the bottom timing belt cover. how do i go about removig it? I will be replacing the stock motormounts with Innovative motor mounts.
Re: help: front motor mount engine bracket
if you're talking about the actual mount...you need to use a jack with a piece of wood in between it and the oil pan to gently slightly raise the engine to remove the timing side mount
Dangger
11-27-2006 07:41 AM
