How to replace your RW Defrost burnt out bulb
Old 01-09-2013, 01:24 PM
drgerry's Avatar
Default How to replace your RW Defrost burnt out bulb
This is for the dash light bulb that illuminates when the lights are on, not the orange light that comes on when the defrost is on.
Follow the pictures. The only tricky part is getting the blue cover off without tearing it. Using a Exacto knife helped, but some still stuck to the bulb.
You can check to see if the new bulb works by putting in back on the switch backwards, mount the base to the prongs and let the bulb stick up. Then turn on the lights and see if it's working. After you verify, pull it off and put it into the hole. (see next post)
Old 01-09-2013, 01:25 PM
drgerry's Avatar
Default Re: How to replace your RW Defrost burnt out bulb
checking the bulb
Old 01-10-2013, 03:39 AM
H-T Order of Merit
TouringAccord's Avatar
thanks for the post, I've added links to this and the emergency switch bulb replacement to the FAQ
GermyLin
10-08-2018 10:17 AM
mr poo
Honda Civic (2006 - 2015)
06-21-2018 11:18 AM
OneFire
12
06-30-2011 06:38 PM
Quick Reply: How to replace your RW Defrost burnt out bulb
