EF Civic heater blower motor not working
Old 12-27-2012, 09:00 PM
90ED6LSV's Avatar
Icon2 EF Civic heater blower motor not working
So I've had my car for a few years now and over the past couple years my heater speeds have been going out, first it was speeds 1/2 and then 4, and then speed 3 would only work if I wiggled the lever to a certain spot..
So now no fan speeds work. I've recently replaced the blower motor resistor pack because I heard that was the problems. But it still doesn't work. The climate control unit has the a/c button, which lights up when i press it...
Anyone have suggestions?....
Old 12-28-2012, 09:00 AM
90ED6LSV's Avatar
Default Re: EF Civic heater blower motor not working
bumper
Old 12-28-2012, 10:36 AM
RuneRavenX's Avatar
Replace the blower motor
Old 12-28-2012, 11:02 AM
Black4thgenEF's Avatar
Check and see if you're getting power to the blower motor. If you are and it isn't spinning, replace it. If you aren't, it could be the actual switch that is bad.
Old 12-29-2012, 11:17 PM
90ED6LSV's Avatar
how do I check the blower motor for power? I'm an idiot when it comes to things like this with wiring...
bump
Old 12-30-2012, 10:19 AM
Unplug the motor and use a voltmeter to see if power is reaching the plug. There are only two pins/wires -- power and ground so it's easy to check.
Re-reading your original post it does sound like your switch could be broken. Usually when the resistor goes, you still have the highest speed working. I have seen blower speed switches fail before. With that said, it would still be a good idea to check the motor for power first.
Old 12-30-2012, 10:31 PM
90ED6LSV's Avatar
alright cool thanks man. And by switch, are you talking about the whole climate control thing?
Old 12-31-2012, 06:42 AM
By switch, I mean the device that has the power settings **** sticking out of it. I don't remember if it separates from the rest of the climate control, someone else will probably know though.
pityocamptes
08-09-2014 09:03 PM
s13hero
Acura TL, RL & ZDX
08-13-2011 03:03 PM
94trouble
11-11-2010 05:50 AM
untitled23
09-02-2010 02:56 PM
Dbach
11-12-2008 12:01 PM
Quick Reply: EF Civic heater blower motor not working
