Diy catch can, filter venting or can I simply drill lots of holes on the top?
Old 12-08-2012, 02:01 PM
Vagitarian's Avatar
Default Diy catch can, filter venting or can I simply drill lots of holes on the top?
Hey guys, I am making a catch can for my setup. I am stuck at how to fabricate the top though.
I have 3 lines coming from my engine to the can, drain **** at the bottom, baffling/steel wool between the inlet and vent, but I cant decide on how to vent.
I see most people use filters on top, but 3 of those is a little expensive, I dont have them, and would take up 2" more height.
Can I simply drill holes in the sealed top and "vent" to atmosphere out the top??
I assume all the oil would get trapped in my thick wool and baffling, and only air would be escaping the top. Aside from the smell, is there any downfalls to simply drilling holes?
Old 12-08-2012, 02:23 PM
Good, Bad…I'm the one with the gun
Ash J. Williams's Avatar
Location: Trapped in time, Surrounded by evil, Low on gas
Default Re: Diy catch can, filter venting or can I simply drill lots of holes on the top?
why do you people insist on atmosphere venting? you know, if you apply vacuum to it, your rings will thank you. route the top to the intake tube on your compressor inlet.
Old 12-08-2012, 02:24 PM
Who is Mr Robot?
wantboost's Avatar
I have a catch can built by some Japanese race shop where they used a piece of metal with holes in it as the outlet, its simply a square on top. I'll post pics if I can find them
Old 12-08-2012, 02:44 PM
KevinEF7's Avatar
I would say its fine as long as the top drilled holes arent right beside the inlet of the 3 ports, youd want the air/oil/vapour to be forced through the steel wool before being allowed to escape
Old 12-08-2012, 02:47 PM
Vagitarian's Avatar
Well I figure holes on the top would be fine but was not sure, since the filter is essentially just letting air escape the top. I suppose there an extra filter, but I believe my thick steel wool would be enough filtering
Old 12-08-2012, 03:03 PM
Who is Mr Robot?
wantboost's Avatar
Yea on this can the outlet is on the other side of the inlets... as long as you have sufficient baffling and steel wool in the can, nothing should come out of the vent... I would however put a drain back in since rye can will fill up
Old 12-08-2012, 03:04 PM
i do hope your inlets go to the BOTTOM of the can.
Old 12-08-2012, 03:16 PM
spAdam's Avatar
Steel wool sucks and rusts and falls apart. Use this stuff:
Old 12-08-2012, 03:22 PM
Vagitarian's Avatar
Why would the inlets be at the bottom? Then the tank would never be able to accumulate any oil?
Old 12-08-2012, 03:56 PM
the inlet and outlet need to be on the opposite side of the separating media, otherwise the contaminated air will simply get sucked back in the engine and the oil and water vapour will not have time to condense and fall out.
Old 12-08-2012, 03:57 PM
Who is Mr Robot?
wantboost's Avatar
The inlets on the bottom would never work.. they would just fill with oil and the can would be pointless
Old 12-08-2012, 04:02 PM
give me a minute to draw up a simple sketch.
Old 12-08-2012, 04:20 PM
here you go
Old 12-08-2012, 04:24 PM
spAdam's Avatar
I need to finish designing the check valve that I came up with. Basically a pcv valve. Has a light spring so that any pressure (2psi or whatever depending on the spring) in the can allows it to purge to the atmosphere. Plumbs to the intake tract otherwise. Best of both worlds.
Old 12-08-2012, 04:25 PM
ideally, the can should only see vacuum
Old 12-08-2012, 04:26 PM
Who is Mr Robot?
wantboost's Avatar
We don't run a closed system... we vent crankcase pressure to atmosphere
Old 12-08-2012, 04:32 PM
i know, and i still have see no point of that. the separator media, the separator can itself doesn't do much that way.
however, even with venting, you simply vent the plug that usually connects to turbo inlet
Old 12-08-2012, 04:37 PM
spAdam's Avatar
Ideally.
I want to add a spare MAP sensor to the top of my can and log it one of these days, to see if it's something worth pursuing. Either way, I want something better than venting to atmosphere for sure. Used to run an exhaust scavenge setup in my old car. Worked awesome. Don't care to do it on a car with a cat though.
Old 12-08-2012, 04:40 PM
Who is Mr Robot?
wantboost's Avatar
The crankcase pressure leaves the motor on its own... path of least resistance.
And as the crankcase pressure is forced through the catch can that's how the media works
Old 12-08-2012, 04:41 PM
Originally Posted by spAdam
Ideally.
you can simply route the outlet to the turbo intake, there is plenty of vacuum there.
Old 12-08-2012, 04:42 PM
sure, but at the very least follow the diagram i posted. otherwise the vapour comes in one way and leaves out of the other.
Old 12-08-2012, 05:11 PM
Who is Mr Robot?
wantboost's Avatar
It comes in and leaves the outlet.... what's so hard about that?
And with plumbing it back to the turbo inlet you risk contaminating the intake charge
Old 12-08-2012, 05:24 PM
nothing hard about that, it's inefficient. if you plumb it back to the turbo inlet and with proper media, you only introduce the gas vapour, which should be burned by the engine anyway.
i understand the reasoning if the car is a race car and not wanting to lower your octane rating with that, but then, you shouldn't have a cat and run the exhaust scavenging system instead.
Old 12-08-2012, 05:30 PM
Retired Moderator
EsotericImage's Avatar
Alot of boost set ups do not run a tube to the inlet of turbo.. Usually just a filter. So theres no place for any vacuum location. If the turbo inlet is pointing towards pass side, then theres room for an inlet tube, but most dont run one cuz the slave is right there.
Also, Alot of people do not want to let the oil vapor hit the blades.
Thus venting to atmosphere is the only option. Theres always the slash-cut option on the exhaust.. but then you have oil vapor in the exhaust.. again.. atmosphere is the other option..
As far as the rings, some evac is better then no evac. Ive seen plenty of set ups w/o any evac route..I wonder what those rings look like?
99% of the time on street cars the car is in vac anyways.. using a PCV from a turbo Supra will close when theres boost and keep it open during vac. That way you have the best of both worlds.
Old 12-08-2012, 05:34 PM
Who is Mr Robot?
wantboost's Avatar
I don't run cats on anything... not even my 1 ton van that I use to tow and do track support local.
The vapors from the crankcase no matter how clean will still contaminate the intake charge and cause issues with tuning, carbon build up on intake surfaces and intake valves, and cause a false air fuel reading
Quick Reply: Diy catch can, filter venting or can I simply drill lots of holes on the top?
