Squeak when A/C is on
Old 11-26-2012, 01:57 PM
lithium_mt's Avatar
Default Squeak when A/C is on
My 1996 Civic often makes a short squeaking noise when the a/c is on and I release the accelerator pedal at 4,000+ rpm. This happens even if the engine is in neutral gear. I don’t think it’s the a/c belt because as far as I know the belt turns even when the a/c is off. Could it be the a/c clutch perhaps? The car has a B16A2 engine.
Old 11-26-2012, 02:01 PM
Former User's Avatar
Default Re: Squeak when A/C is on
Replace and tighten the A/C belt. Then go from there.
Old 11-26-2012, 02:21 PM
lithium_mt's Avatar
Why would the belt only squeak when the A/C is on? Would I have to refill the system with refrigerant after changing the belt? Thanks.
Old 11-26-2012, 03:06 PM
It's the only time when the compressor clutch engages and places force on the belt.
Only if the refrigerant charge is low.
phat00civic
03-07-2012 06:30 AM
accord_2dr
01-18-2008 06:12 PM
nigelnuggets
11-19-2007 05:52 PM
dizzogotvtec
05-13-2006 01:49 PM
EVOTHIS
02-09-2002 10:55 AM
Quick Reply: Squeak when A/C is on
