What's needed for ITR f&r sway bars on EG?
Looking to run a pair of ITR sway bars on my 93dx hatch.
Setup will be as follows:
GSR F&R disc brakes
90-91 civic ex master cylinder
40/40 prop valve
Stainless brake lines
ITR rear lca's
ASR subframe brace
I'm most concerned about the front, because I'm unsure which lower control arm I need if the EG won't work.
Thanks for any advice
GSR F&R disc brakes
40/40 prop valve
ITR rear lca's
ASR subframe brace
Re: What's needed for ITR f&r sway bars on EG?
for the front i belive the dx comes with no sway bar from oem so ur gonna need diffrent lower control arms since u need a hole to mount the sway bar too. then ur gonna need the bar and hardware. homes and bolts are there already from factory. for the rear u can run the after market lower control arms or stock if they have the hole for sway bar. ur gonna need a brace to help support it and not tear out the subframe. the endlinks id recommend adjustable ones and other then that u seem set.
o how big is ur master cylinder? gsr is 15/16
