exhaust rattle?
Old 09-01-2012, 04:43 PM
mangogsr's Avatar
Default exhaust rattle?
the exhaust on my 97 gsr is completely stock except for a greddy can. whenever i get to about 3300 rpms there is a rattling noise from the resonator behind my cat. there seems to be a small hole in the resonator. how can i get rid of this rattle? if necessary i have a resonator from a 97 prelude i could replace it with. all help is appreciated. thanks guys
Old 09-01-2012, 04:54 PM
vtaker's Avatar
Default Re: exhaust rattle?
Usually the problem is with the down pipe aka A-pipe/Y-pipe. The way it works is there is 2 layers of piping separated by some insulation material. The insulation material wears away and then the pipes rattle on each other.
The two ways to fix it are tac welding the inner pipe so it's centered or just getting a header and downpipe setup. An exhaust shop will tac weld it and fix the hole in the resonator for $20 or less.
Yours is like this:
Should be like this:
Old 09-01-2012, 05:03 PM
mangogsr's Avatar
Ill go take it apart and check now. thanks. ill let you know if that was the problem.
Old 09-02-2012, 06:36 AM
mangogsr's Avatar
Yours is like this:
IMAGE#1
IMAGE#2
took down pipe off last night and it seemed to still have the insulation separating the two pipes. im thinking its the resonator. there might be a loose chamber in there that is hitting against something inside. what should I do?
Posted from Honda-tech.com App for Android
Old 09-02-2012, 01:30 PM
vtaker's Avatar
an exhaust shop can cut it off and weld a new one on or just buy a catback.
VTECME
04-11-2007 09:14 AM
civic-cpe
09-28-2006 08:30 PM
litterbox
07-26-2005 04:14 PM
WhiteGSR95
09-29-2004 09:27 PM
Quick Reply: exhaust rattle?
