What spark plugs do you like for stock civic?
Old 08-26-2012, 07:02 AM
skinney6's Avatar
Default What spark plugs do you like for stock civic?
what do you all use?
and what do you use to gap them?
I put some NGK's in my girls accord and they had tiny electrode and for some reason it was a pain to gap accurately.
Old 08-26-2012, 07:28 AM
Dontoh's Avatar
Default Re: What spark plugs do you like for stock civic?
not exactly sure why, but many people swear by ngk's in hondas and nothing else
Old 08-26-2012, 07:44 AM
JuggerNaut-CTR's Avatar
as long as you get the plugs the manual calls for, than it really doesn't matter what kind you use on a stock motor.
Old 08-26-2012, 08:13 AM
skinney6's Avatar
the NGK that come when i put in my gx model are like $13 a piece
but i seems to run fine on regular plugs
thanks!
Old 08-26-2012, 09:49 AM
fragmare's Avatar
NGK Platinum all the way. NGK Iridium plugs would be nice, but $10-11 a plug? GTFO...
Old 08-26-2012, 09:58 AM
Master Detailer
98civdx's Avatar
Regular old NGK plugs. just make you get the correct heat range, and gap them correctly.
Old 08-26-2012, 10:50 AM
cheese187's Avatar
Ngk
Old 08-26-2012, 11:33 AM
fragmare's Avatar
You gotta gap the higher end plugs (non copper) with a wire gapper. The coin type gapper will bend up the little electrode.
That being said, most NGK plugs come pregapped to .044 in. My motor calls for .043 in. Close enough to just check the gap and throw in there.
Old 08-26-2012, 12:13 PM
EyeHasSol's Avatar
I run NGK plat plugs. They seem to be better than other brands I have used.
Jimi Hondrix
07-19-2015 05:22 PM
sp00led
06-10-2004 08:45 PM
PTownGSR
06-05-2002 05:14 AM
migo
11-09-2001 07:39 PM
Babalouie
06-24-2001 07:33 PM
Quick Reply: What spark plugs do you like for stock civic?
