hi guys! new integra owner here!
#26
Who the fack changed my title?!
Re: hi guys! new integra owner here!
If I posted better pix, Honda tuning or superstreet might try and put me in their magazine....
#28
So I picked up a sunroof and a complete steering column for 40 BUCKS
Also went to el junk yard and got the clips to the windshield trim, a cover for the pass side door mirror, and a driver's side turn signal. Mine was missing the piece that went into the bracket on the bumper. Also went with a buddy of mine to get a window motor and a arm rest cover
#34
as far as i know...im the only person in houston who has done this to a car like this.
more later
more later
#38
I have yet to see anyone else do it on here OR in Houston. So some ones gotta do it. And frankly, yes i do like it. Beats running the real **** and paying half or a 1/4 of the price for Tue real ****
#39
You seem to know a lot about cars.. haha.... I'm new to this, just turned 16 and just recently became very interested in cars. I bought a 1990 Acura Integra GS for 1300 a few months ago and I'm wondering where/how should I learn things about my car and other cars?? I am very interested and willing to learn. Any help will be great! Thanks!!!!!!
#42
On a side note, performance wise, I added my slim fan and shroud I had laying around recently. Just debating weather to wire it up to stock fan wires or run a switch under the dash.
#44
big things coming soon:
jrsc'd lsv with a shot of dope
everything redone car and motor/tranny wise. will post more later.
as stated in my other build thread(another nasty hatch from tx) please bare with me, this is not the only car i am building and i work a full time job, so my time is limited to post/update
-sh!ft
-sh!ft
#45
Sorry for a late update.
So far, this is what's been done to the motor Im about to drop in:
Purchased:
New oil pump
New water pump
New timing belt
New valve cover gasket set
New oil pan gasket
New rings
New bearings
New thrust washers
Itr pistons
Cleaned up ls rods
Polished crank with new ball bearings pressed in
Rehoned the block at std mm specs
Decked the block
Gsr girdle for block
Wilwood 4 piston calipers
13 inch rotors
Act stage 2 clutch
Act flywheel
Nitrous kit
Still need:
Arp rod bolts
Repaint the valve cover
New distributer
Intake gasket
Exhaust gasket
Jrsc rebuild kit
New distribution blocks for nitrous
New nozzles for direct port
Tubing and fittings for lines to dist blocks and nozzles
Purchased:
New oil pump
New water pump
New timing belt
New oil pan gasket
New rings
New bearings
New thrust washers
Itr pistons
Cleaned up ls rods
Decked the block
13 inch rotors
Act stage 2 clutch
Act flywheel
Nitrous kit
Still need:
Arp rod bolts
New distributer
Intake gasket
Exhaust gasket
Jrsc rebuild kit
#46
small update....
did some maintenance as well as some additions
new rack and tie rods and rear mount
new rear brace(well its new to me
new s2k seats
swapping seat pans
swapped out the plm race header for an itr
added some new stuff under the hood
bought this
still waiting on getting a fewmore things as well. like i said before this is not my only project(i said that here or on my other thread lol) so its sludging along, but hella parts are stacking up. i also have a bike so that takes up a lot of my time and funds as well.
more later
new s2k seats
swapping seat pans
bought this
more later
#47
picked up another set of black housing lights for hella cheap off a friend.
just need the rad support and the bumper support(which im getting for free from a friend who owed me a favor) and im crisp.
as you can see i did try the toothpaste trick(it worked) but plastic-x will be bought tomorrow only because vato zone was closed when i got home.
#50
was about to say not a fan of the carbon... maybe it was just the picture quality??
but those last two pics look pretty awsome!!
mayb the night time pic's hiding the blemishes
