Brake lights not working???
Old 07-02-2012, 09:27 PM
dragonkx's Avatar
Default Brake lights not working???
hi, I have a 2000 honda civic si. all of a sudden my brake lights dont work, all 3 of them when i step on the brakes. I changed the bulbs and still nothing. But when i press my alarm to arm or disarm the brake likes (red) blinks ones as door is unlocked etc. any ideas? The middle brake light and the back window looked black alittle and was replace, but non still work when i step on brake. any ideas?
Old 07-02-2012, 09:41 PM
99gsvtec's Avatar
Default Re: Brake lights not working???
Might be the stoplight switch located under the pedal id check fuses first though AutoZone normally sells the switches for around $20.00
Old 07-02-2012, 10:30 PM
dragonkx's Avatar
i think so too that it might be the brake switch, because the lights do work, just not when i step on brake, and i checked the fuses their fine.
Old 07-03-2012, 11:22 AM
fcm
Old Fart
fcm's Avatar
Fuse or brake switch, check for power to the brake switch even if the fuse is good.
I am also guessing it is the park lights that flash when you arm/disarm the alarm, not the brake lights, or does the high mount, [center] brake light also flash when you arm/disarm? 94
Old 07-09-2012, 06:09 PM
dragonkx's Avatar
how would i check the power to the brake switch? and the fuses are good, the brake fuse is labeled tail light, correct? cuz i changed it too. and i changed the brake switch nothing. still doesnt work.
Old 07-10-2012, 12:37 PM
faded215's Avatar
Test light, or a dvom
Old 08-01-2012, 09:33 PM
dragonkx's Avatar
tested fuse box with voltmeter some had no power. took it to the shop. they said wires were fried, swappe with new wires and brakes work again
d0ugch0i
02-16-2024 04:44 PM
cavie
Suspension & Brakes
10-03-2008 12:09 PM
RanCRX
06-09-2008 07:35 PM
LOWLIFEHATCH
01-30-2004 01:25 PM
94TealGSR
10-25-2002 11:41 AM
Quick Reply: Brake lights not working???
