Best Spark Plugs
Old 06-04-2012, 04:53 PM
ChalmersP's Avatar
Default Best Spark Plugs
Hey guys, Im looking at getting a new set of spark plugs and have read mixed reviews on the Bosch ones, and not many other reviews of the other brands. What do you guys use? Do you notice a significant difference over the stock ones?
Thanks!
Old 06-04-2012, 06:25 PM
redbull-1's Avatar
Default Re: Best Spark Plugs
For the most part, you will not notice much difference unless your spark plugs were worn badly. What year and model is your car? The respective NGK plugs for the different Honda models and years work perfectly fine.
Old 06-04-2012, 07:34 PM
qwrty's Avatar
NGKs for me.... all of our stock and modded cars uses these no issues eversince!
Old 06-05-2012, 04:45 AM
jlk16188's Avatar
agreed
Old 06-05-2012, 06:53 AM
DominicanFlow's Avatar
NGK Cables and plugss
Old 06-05-2012, 07:13 AM
h22teggy95's Avatar
NGK highly recommended
Old 06-05-2012, 09:22 AM
ChalmersP's Avatar
Alright! Im getting the impression that NGK is the way to go! What one though? Theyve got quite a few from what I see
Old 06-05-2012, 11:24 AM
qwrty's Avatar
ive used ngk bkr6e/bkr7e on my 2 stock Vs... or go for the oem one! i think its posted on a
sticker under the hood or just search it online.. it should be cheap!
http://www.hondapartsnow.com/cr-v/98...~ca13s100.html
Old 06-07-2012, 05:02 PM
SuzukaBlueS2K's Avatar
Like above said, can't go wrong with NGK's in a Honda.
Old 06-08-2012, 09:02 AM
Janet@bisimoto's Avatar
NGK!
Old 06-08-2012, 11:30 PM
el crapitan's Avatar
platinum or iridium will last longer. however, any plug with the correct heat range and gap will perform just as well, but will wear sooner.
i go with the v-power's myself
Exeed
02-24-2007 10:39 PM
veritasaequatis
14
02-06-2007 03:08 PM
Nicks95GSR
11-30-2006 10:42 PM
gsrguy
01-23-2004 07:04 AM
HybridGSR1
10-05-2002 08:45 PM
Quick Reply: Best Spark Plugs
