valve cover paint?
Old 04-11-2012, 02:01 PM
lilboxx's Avatar
Default valve cover paint?
does anyone know of a good paint to use on valve covers? one that will last and not chip off after a month
Old 04-11-2012, 02:05 PM
DELshaneSOL's Avatar
Default Re: valve cover paint?
Use heat paint of some kind If you do it right and prep real good it won't chip
Old 04-11-2012, 02:06 PM
Global Moderator
Jimmy's Avatar
VHT wrinkle black or red.. should be able to google it.
Old 04-11-2012, 02:08 PM
EH2Kevin's Avatar
Old 04-11-2012, 02:24 PM
dunkingmofo's Avatar
I use that metallic high heat paint in the spray can from advance Auto parts works like a charm just make sure I sand it good and prime it before using the color paint
Old 04-13-2012, 01:30 PM
Andrewzabomb's Avatar
i used red high temp brake caliper paint on my valve cover, been painted for 6 months or so and no chips or weird deformations
Old 04-13-2012, 01:56 PM
KINGVEM^^ED6's Avatar
Krylon paint hasn't chipped I cleared it too
Old 04-13-2012, 02:37 PM
Crazy Honda Guy
Deetz's Avatar
Here's a shot of how VHT wrinkle comes out
Old 04-13-2012, 02:44 PM
did u get ALL the old paint off and prime it?
Old 04-13-2012, 02:55 PM
AReynolds91's Avatar
Ive always been a fan of powder coat, but really any type of paint is usable, as long as you prep the right way.
Old 04-13-2012, 03:27 PM
Crazy Honda Guy
Deetz's Avatar
^^ This is how my powder coated valve cover came out, back in the day
Old 04-13-2012, 03:33 PM
EH2Kevin's Avatar
This looks awesome.
Old 04-13-2012, 03:44 PM
spAdam's Avatar
Powder coat IS awesome. But for the investment of a can of VHT and a can of Tal-Strip I can get really good results four times before I equal the cost of taking it to a powder coater once.
Old 04-13-2012, 04:43 PM
This what my valve cover and intake pipe look like with the right prep and VHT paint from advance.
Old 04-13-2012, 05:59 PM
brake caliper paint
Old 04-13-2012, 06:03 PM
EK9
Dc4LsTeG's Avatar
Anyone using regular spray paint and adding clear coat?
Old 04-13-2012, 06:17 PM
jbpnoman's Avatar
You should use high temp, not just regular spray. Engine bay temps will maul regular spray real quick.
Old 04-13-2012, 06:25 PM
EK9
Dc4LsTeG's Avatar
Even with a high temp clear?
Old 04-13-2012, 06:30 PM
spAdam's Avatar
Tal-Strip, mask, acetone, VHT, bake. Came out perfect.
Old 04-13-2012, 08:49 PM
Arthas's Avatar
Nothing but powder coat touches any of my valve covers.
https://honda-tech.com/forums/honda-acura-28/post-your-powdercoated-painted-anodized-gold-dipped-shaved-etc-valve-covers-2672726/
Valve cover fashion tips
Old 04-14-2012, 02:59 AM
jbpnoman's Avatar
Yes. Different chemical compositions to the paint.
Personal opinion: Powder coating is a waste of money, and a played out scene. If I'm showing off my valve cover, I'd rather show off the time and effort I put into painting it than show off how much I can spend on having someone else do it for me.
Old 04-14-2012, 04:52 AM
bgguyshatch's Avatar
Sorry but the wrinkle is nasty just use highroad temp engine paint just make sure.its preped right and you'll have no problems
Old 04-14-2012, 08:24 AM
gzes's Avatar
srry to thread jack but would the spark plug cover on b16 be bad to have plastic dipped black? I mean its plastic and I don't think it'd get nasty... I painted mine with the plastic dip. Still have to get engine to run then I will see what happens lol
Old 04-14-2012, 08:49 AM
hannslebo's Avatar
This is my last car....I used paint thinner to get off the crinkle3 .
Not really a fan of the crinkle.
Then sanded a bit and used some regular ol rust oleum to paint.
I did 3 coats with the white rust oleum and then applied 2 coats of clear.
I think it turned out pretty good.
Old 04-14-2012, 09:39 AM
spAdam's Avatar
Ehh its a matter of opinion, I personally don't care for valve covers that aren't a stock color. But yes, it can't be restated enough... the prep is the most important part.
Quick Reply: valve cover paint?
